Big Decision! Transmission questions
Old Jul 2, 2007 | 08:52 AM
jruss1601's Avatar
Ok. I have a big decision to make and i need some help. I bought a maxima that needs a motor. I have a motor to replace it. No biggie. The bad motor (motor A) came with a manual transmission. Good motor (motor b) came with an automatic. Both motors with transmissions are out of the car.
I forgot why but i took the manual to a transmission shop and he said when you turn the input shaft, it sounds horrible. Sounds like the bearing fell off inside and i need another transmission. Well, a manual from a junkyard costs 500 bucks. I have an automatic so it would be free but i'd have to convert everything in the manual to an automatic. So that would be more work.
Also, i was looking to sell this max once it was done. Automatic would be easier to sell than manual but more work for me to convert over.
On a side note, i just got a job that requires me to move. My parents wouldn't mind holding everything here for me but i need to figure out what to do with it.
Can i fix this transmission? My options are fix transmission, get a used transmission but spend alot, transfere all manual stuff to automatic, or just sell everything which i don't really want to do. What should i do? Really need some serious help on this. Thanks
Old Jul 2, 2007 | 10:49 AM
nicks79's Avatar
I just pulled motor from Auto SE. I have everything in Auto SE that you might need to conver. Computer, harness, torque converter, etc. I am putting together a manual SE.. Interested in any parts. Cheap!!!!
Old Jul 2, 2007 | 10:57 AM
Hectic's Avatar
Fix the transmission, or at least open it to know for sure if it's broken. If you're capable of doing all the work you're doing already, then you're capable of fixing the manual tranny. Front input shaft bearing is a very common problem, it's also cheap to fix if you do the work yourself. If you don't have a full automatic parts car available, this is the easiest option.
Old Jul 22, 2007 | 11:19 PM
writes1's Avatar
I have a tranny problem too.
When I put my 93 GXE into drive (automatic) into drive, the car won't move. But when I put it into 2nd the car finally moves. Once the car is moving, I put the car back into drive and everything is fine.
Sounds like I need to new transmission from what I have been hearing from family. My question is should I have a shop do the work for me? Are there any alternative? I'm fairly mechanically inclined and short on cash. What would be my best option at this point? I'm not sure if I want to pay more than $1000 for this car. Blue book is only $2500.
Old Jul 22, 2007 | 11:41 PM
Alex_V
Sounds like a shifter bushing is bad. Do you have problems with Park as well?
~Alex
Old Jul 23, 2007 | 12:19 AM
writes1's Avatar
Nope. No problems with the park.
Old Jul 24, 2007 | 10:50 AM
propz''s Avatar
man its an easy fix i sold the car to you =D ... or just go-to www.car-parts.com heres one
1993
Transmission
Nissan Maxima 3.0D5SAC,DRIVEN 1500MILES 116,244 A 013429 $248.06 Southern Tier Auto Recycling USA-NY(Beaver-Dams) E-mail 1-800-640-7995
even getting someone to do it would cost less then 500 . and a complete auto swap is nutz. plus why would you want to ruin a good thing..
Old Jul 24, 2007 | 11:41 AM
goon9's Avatar
Manual to auto=possibly worse decision you can make on these cars.
If it's a manual it can be rebuilt.
Old Aug 18, 2007 | 09:21 PM
eman93's Avatar
My auto is out as well. I found a used one to swap out. Can I swap the transmission without pulling the motor?
Old Aug 18, 2007 | 10:35 PM
mikekantor's Avatar
Yes, but the motor should be supported.
Old Aug 18, 2007 | 10:36 PM
Tom's Avatar
Tom
Like Alex V said, it's the shifter bushing. I have the same problem. I just got the bushing from Nissan last week. Part number is 34552-D4000. It set me back $2.96 (two-dollars and ninety-six cents).
sctludwig
Sep 1, 2022 01:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
