Changing the ECU????
Old Jul 18, 2001 | 05:09 PM
Adambrown_2001's Avatar
My friend has a 2001 subaru 2.5rs Impreza and he changed his ECU chip by disconnecting his battery for 45 mins and then driving aggressively. Would this work on a 1990 maxima, or is there a different way to do it???
thanks in advance.
Old Jul 18, 2001 | 05:35 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Huh!?!?!
I'm no expert on Subies, but how the hell does that work?? anyways for our cars you have to buy an upgraded unit from JWT, Superchips or JET. JWT is highly reccomended...will run you $500+ I've heard its very effective after all your I/E, etc. mods are done.
thanks in advance.
Old Jul 18, 2001 | 08:35 PM
MadMaxBrent's Avatar
Learning ECU
I suspect it has forced the ECU into a more aggressive program. Some of the learning ECUs can change their shift patterns based on the inputs that it gets.
So if you disconnect the ECU you are resetting it, then if you drive aggressively it will assume that this is the norm.
Brent.
Old Jul 18, 2001 | 10:14 PM
nodoubt711's Avatar
so if i disconnect my battery for 45 mins, that is how you reset the ecu?
Old Jul 19, 2001 | 01:04 PM
Reset
It should do. Some people disconnect the battery overnight. You can do it also via the ECU diagnostic screw, but the battery method is the easiest.
Brent.
Old Jul 19, 2001 | 01:17 PM
Mizeree_X's Avatar
Getting back to his roots
Re: Reset
So I was curious about this....
When you reset the ECU in the maxima, does it take the first 15 minutes of driving after the reset to 'learn' the driving style. I always see people saying to reset the ECU after each mod so it can take advantage of it, but how exactly does this process occur?
Old Jul 19, 2001 | 01:30 PM
I do not know as to timeframe, but what it does is gets signals from the various sensors and uses those readings to set the baseline for the ECU map after it has been reset.
My Nissan dealer maintains that all mods should be 'plug 'n play' as the earlier ECUs are quite 'dumb'. From my experience though it isn't quite that dumb.
Brent.
220k+ A32
Sep 22, 2015 03:08 PM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
