TiMiNg BeLt
Old Jul 22, 2007 | 07:40 PM
Quickywd01's Avatar
TiMiNg BeLt
Would I be able to remove the timing belt cover on the vg30e alone or do other things need to be removed?
Old Jul 22, 2007 | 07:45 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
welllll.............
it takes like 8 8mm bolts for the top and like 4 8mm bolts on the bottom, but to get to the bottom youll have to take the crank pulley off, and to do that youll have to take the starter off to jam up the flywheel 2 14mm bolts, the crank is either a 24mm bolt or a 27mm bolt depends on the year, then youll have to take off the water pump pulley 4 10mm bolts then the bottom timing cover can come off easily with out breaking or bending it
Old Jul 22, 2007 | 07:51 PM
Quickywd01's Avatar
I just wanted to check out my timing belt so taking off the top half would be enough right? When I bought the car I was told it was done. The spark plugs, wires, cap, rotor, and brakes are new so I just want to make sure that the belt is too.
Old Jul 22, 2007 | 08:03 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
take it off and make shure that it dosent have too much flex 13-14.5 mm you should be good but if there is no way to tell when it was last changed then i would change it, but just to check you could take the top half off make shure everything is clear and run the engine see if there are arent large chunks missing....
Old Jul 22, 2007 | 08:46 PM
Quickywd01's Avatar
Thanks. I'll do that.
Old Jul 22, 2007 | 10:39 PM
maxitech's Avatar
It's gonna take you awhile...the wheel and fender well splash guard need to come off before you can even think about starting in on the engine...I've done the job once and it was enough of a PITA for me never to want to do it again...
Old Jul 25, 2007 | 09:00 PM
Quickywd01's Avatar
Sounds like what had to be done on my sonata. I just want to take off the top cover to check out the belt, not replace it.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
