tranny noise 93 ve 5spd
Old Jul 25, 2007 | 05:46 PM
mofoaka's Avatar
i have this ticking noise comng coming from the tranny, it increases as i accelerate but once i depress the clutch pedal it goes away. but if i'm rolling and put it in gear as i keep the clutch pedal depressed.. the sound reappears. what could this be?
Old Jul 25, 2007 | 07:09 PM
internetautomar's Avatar
mod or sell?
input shaft bearing.
Old Jul 25, 2007 | 09:59 PM
NismoChi's Avatar
Mine had the same noise before i replace the gear oil with some Red Line MT-90.
None after that. Good stuff, try it.
Old Jul 26, 2007 | 12:14 AM
mofoaka's Avatar
could it be the throw out bearing? if it is.. how much is it to replace? and if its the input shaft bearing.. would it be better to just get a used tranny?
Old Jul 26, 2007 | 12:44 AM
NismoChi's Avatar
Think about it, you push the clutch pad in to push the throw out bearing out in order to push the pressure plate to disengage the transmission, if the noise come up at this time, then it would be from the TOB. In you case, yo hear the noise when you engage the tranny, then it have to be coming from the tranny, the input shaft bearing are known to go bad in our car, anyone here can tell you that.
Why would you not consider spending $40 and 15mins to try replacing the gear oil before thinking about getting a used tranny, which would cost you from $600 - $1200 dollars.
Old Jul 26, 2007 | 05:56 AM
Hectic's Avatar
Magic oil isn't going to solve his problem. Might as well save that $40 and put the oil in a tranny that's not going to contaminate it with metal debris.. As in, one without a busted ISB.
Old Jul 26, 2007 | 11:27 AM
blackandwhite's Avatar
To them I'm like an idol
I think MT-90 is BETTER than magic. I changed to it, and it all but eliminated some scratching I was getting from the 1-2 and 3-4 synchos.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
uttadms31
Sep 30, 2015 05:24 AM
