battery and E-brake light
Old Aug 3, 2007 | 06:06 PM
tigga_tha_don's Avatar
Max In Process
well suddenly today my E-brake light and battery light decided to come on E-brake was fully down and i did this multiple times and car is starting up fine with subs on so i figuer battery if fine maybe not any suggestions
Old Aug 3, 2007 | 07:41 PM
Alex_V
Your alt is counting down to its self destruction. Get it to a independant alternator/starter repair shop stat!!
~Alex
Old Aug 3, 2007 | 08:35 PM
goon9's Avatar
~Alex
Yup. Or replace the Alt. yourself
Old Aug 3, 2007 | 09:25 PM
Max In Process
this is goin to b my second one since i recived the car
Old Aug 3, 2007 | 10:03 PM
xx-Marshall-xx's Avatar
kthxbye2u
then you shoulda known... riiiiight?
Old Aug 3, 2007 | 10:06 PM
Max In Process
thats true also could it be cause im running alot of electronics
Old Aug 4, 2007 | 09:20 AM
mooze's Avatar
if you have so many electronics get a hc alt. worked for me
Old Aug 4, 2007 | 07:46 PM
internetautomar's Avatar
mod or sell?
it could be that you bought a cheap alternator from autoblown or the like...
Old Aug 4, 2007 | 08:20 PM
Max In Process
pepboys...
Old Aug 4, 2007 | 09:31 PM
whitemax89's Avatar
Well does ur interior lights dim when the lights went on because if they dont or even if they do i think check ur alt belt first i went in to 1 foot of water and both of the lights went on and the maybe about 15 min they went off. So cheapest part would be the belt and then go to autozone or strauss get ur alt checked and the battery.
Old Aug 4, 2007 | 10:16 PM
saxytothemaxima's Avatar
soo. i guess i should ask this.
when I pull into my driveway at night and go to roll up my windows the lights dim a pretty good bit. Exterior lights and interior Seems to be getting worse.
Old Aug 5, 2007 | 09:50 AM
mooze's Avatar
alt mayb getting weak. but could be dead battery. mine did that with me hc alt until i changed the batter
Old Aug 5, 2007 | 09:58 AM
Alex_V
Id go get the battery and alt tested at a parts store.
~Alex
Old Aug 6, 2007 | 05:25 PM
Max In Process
well battery died before i could get my license but thanks for the help
Old Aug 8, 2007 | 12:09 PM
Max In Process
today in jerseys sweltering heat i went and jacked the car up and i came to find theres no belt on the alternator, my question is could the belt had slipped off so maybe i can just put it on again or shall i buy a new belt. since i cant move the car ill have to go and d.i.y if anyone can provide pics so i can see what it should look like
Old Aug 8, 2007 | 12:16 PM
Greeny's Avatar
¯\(°_o)/¯
Old Aug 8, 2007 | 12:28 PM
Max In Process
thank you GREENMAX i have no belt so wish me luck guys
Old Aug 8, 2007 | 12:58 PM
Greeny's Avatar
¯\(°_o)/¯
Chances are your other accessory belts need to be replaced as well,but if you are just going to put an alty belt on,you will need to remove the a/c compressor belt first.
Also,be sure not to over tighten the belts.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
