dead coil harness or something
Old Aug 4, 2007 | 05:17 PM
mooze's Avatar
i have coil harness thats not doing anything or messed up valve or something. i have skip and my s/p is good and coil is good. i know all coils are good. any fixes? can i just tie it into another coil harness or something?
Old Aug 4, 2007 | 05:20 PM
elusivemax93's Avatar
bro the ignition on the maxima SE VE30DE is sequential it fires individually in order and cant be tied into another coils harness as it will then be firing off the wrong cylinder at the wrong point of timing in the firing sequence. you can get the left or right harness at autozone special order at around 85 dollars last i asked about it. if you know how to remove pins and repair broken or corroded pins that might be your problem in the system.
Old Aug 5, 2007 | 09:44 AM
mooze's Avatar
well its not the coil harness. put the meter on it and it pushin 12.4 constant. coils good plugs good and injectors good. whats next?
Old Aug 5, 2007 | 10:13 AM
ok first and formost what is the exact symptom your having? Because i fully dont understand what is wrong if its not the coils or wire.
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
zmcneely13
Sep 26, 2015 02:26 PM
