What spark plugs are in your Max
Old 08-05-2007, 07:40 PM
Nmax92's Avatar
Just want to know what plugs are you guys using in your 3rd gens.
Any recommendations? I'm leaning to NGK's Irdiums
Nmax92 is offline
Old 08-05-2007, 07:55 PM
mod or sell?
internetautomar's Avatar
I had OE NGK aser plats on mine.
internetautomar is offline
Old 08-05-2007, 07:58 PM
Nmax92's Avatar
are the iridiums crap? is there a noticeable difference between the OE and the iridiums
Nmax92 is offline
Old 08-05-2007, 08:01 PM
whitemax89's Avatar
I got Denso wire set looks like it made to last.
whitemax89 is offline
Old 08-06-2007, 04:13 AM
¯\(°_o)/¯
Greeny's Avatar
This is about sparkplugs,not wire sets.
Greeny is offline
Old 08-06-2007, 06:19 AM
mod or sell?
iridiums are just a harder metal so they last longer IIRC.
there are cars that do not like anything other than the OE specified plug. Ours are fussy only to brand.
Old 08-06-2007, 07:49 AM
AzureblueZ's Avatar
NGK's FTW! Stock NGK's work surprisingly well, even in highly modded cars. One of our z31 (300ZX) guys is still running the stock OEM NGK's and making over 400HP:
http://www.redz31.com/
AzureblueZ is offline
Old 08-06-2007, 10:39 AM
bhunter's Avatar
I ran autolite plats in two of my third gens with zero problems.
bhunter is offline
Old 08-06-2007, 10:51 AM
heresmymind
iridiums FTW
Old 08-06-2007, 12:32 PM
CyMax's Avatar
Good old basic NGK's for 2 something each. Screw a 66$ plug change, humm thats about 10 plug changes for me.
CyMax is offline
Old 08-06-2007, 03:49 PM
kthxbye2u
xx-Marshall-xx's Avatar
i deff got iridiums 9's
xx-Marshall-xx is offline
Old 08-06-2007, 09:16 PM
Way out West
Cliff Clavin's Avatar
I use NGK. My JDM engine has the stock platinums, but I had coppers in my engine.
A nissan tech that used to be on this board told me that other plugs (especially Bosch) can cause problems with VE30DE coil packs over time (doesn't apply to VG engines). He thought it could be related to some of the stalling/bucking issues some people have, but not directly. Indirectly, he thought they were messing up the coil packs, which were causing the problems. It was only his theory, but he told me on numerous occasions when VEs would come in with those kind of problems, they had Bosch plugs.
Cliff Clavin is offline
Old 08-06-2007, 09:58 PM
elusivemax93's Avatar
NGK iridium IX's here
elusivemax93 is offline
Old 08-07-2007, 01:25 PM
kthxbye2u
i did have Bosch.... before this forum and the car was so CRAPPY!!!! when it went to idle it would almost want it to stall, but it would climb back up
after installing new NGK's the problem stopped
Old 08-07-2007, 02:05 PM
The Computer Guy
nForce's Avatar
NGK Iridium IX
They work great had them in my max for about 2 years now
nForce is offline
Old 08-07-2007, 02:27 PM
mooze's Avatar
NGK Iridium IX
mooze is offline
Old 08-07-2007, 06:30 PM
Alex_V
NGK copper's. I'd rather replace more often in case something goes wrong, ie an injector does and fouls a plug, etc. Plus its a little cheaper
~Alex
Old 08-14-2007, 10:06 AM
The Max's Avatar
Autolite 3923 (copper), as recommended by Jacobs Electronics back in 2000. Their ignition systems aren't made to work with platinums since the electronics rely on the resistive characteristics of a copper plug as opposed to the resistive characteristics of platinums.
The Max is offline
Old 08-22-2007, 01:58 AM
renzokuken1227's Avatar
does anyone know a good place to buy the NGK's ?
renzokuken1227 is offline
Old 08-22-2007, 06:40 AM
stevex's Avatar
in november 2006 I replace spark plugs with BOSH FR7DCX (6pcs). From then I drive about 15.000 km ( 9.300 miles) without problems.
stevex is offline
Old 08-22-2007, 08:17 AM
lleyleber's Avatar
not sure...
lleyleber is offline
Old 08-22-2007, 08:59 AM
Alex_V
Advance auto, autozone, any parts store that sells NGK stuff...
~Alex
Old 08-22-2007, 09:45 AM
¯\(°_o)/¯
Greeny's Avatar
~Alex
Idiotzone does not stock NGK.
Greeny is offline
Old 08-22-2007, 10:05 AM
Alex_V
ah, I dont buy anything from them around here, they live up to that name. NAPA and Advance are the only good places. And I cant remember if NAPA has NGK..
~Alex
Old 08-22-2007, 10:07 AM
White_Shadow
rmdl51's Avatar
True! Lottozone and cheapboys never have good stuff for our cars.
I bought my NGK Iridiums from ebay with a good reputation seller
rmdl51 is offline
Old 08-22-2007, 10:09 AM
¯\(°_o)/¯
Greeny's Avatar
~Alex
Yeah,napa stocks ngk,as does advanced..
Greeny is offline
Old 08-22-2007, 10:35 AM
bigb007's Avatar
NGK Iridiums in my 94 GXE.
bigb007 is offline
Old 08-22-2007, 11:12 AM
STFU n00b!
Matt93SE's Avatar
as long as you stick with NGK, you'll be fine.
the VG does best with the copper plugs. no notable power gains with anything else, only plug longevity.
the VE doesn't seem to have an issue running the coppers, although it recommends the platinums. I run the copper in mine and change them every spring during my annual tuneup.
the iridiums don't do anything special for either car. no dyno proven results anyway.
Stay away from bosch with the VE, period. the VG doesn't care quite as much, but the VE is pretty high strung. it likes NGK and NGK only. doesn't matter which ones, as long as its NGK.
Matt93SE is offline
Old 08-22-2007, 11:35 AM
mod or sell?
I sell NGK
Old 08-22-2007, 01:05 PM
- Product of Maxima.org -
ustfdes's Avatar
NGK iridium iX, 2 years strong. tried bosch, and it sounded like i was running on 3 cylinders.
ustfdes is offline
Old 08-30-2007, 08:17 PM
maximagxe90's Avatar
Once there were bosch in my car, and my car would bog down and run real crappy. When I put in Ngk, the car ran fine.
maximagxe90 is offline
mvm062
11-30-2020 09:00 AM
knight_yyz
11-06-2015 02:34 PM
JoshG
51
09-21-2015 10:41 PM
chernandez1278
09-16-2015 01:18 PM
Quick Reply: What spark plugs are in your Max
