Grinding/Grating noise from front tire after putting axel in
Old Aug 10, 2007 | 10:04 PM
hoyshnin's Avatar
Baby's on the Half Tip!
I had a torn cv boot and removed the axel to replace it. After I was done I put a new c clip on it and tried to tap the axel back in place. It would not go in no matter how much pounding of a 3 lb sledge hammer I did. Finally I took off the new c clip and put on the old one and it went right in.
At least I think it went right in. The axel went in the exact same distance as it did with the new c clip, but it held in place after I put the old ring back on and I couldn't just slide it out (though I could pull on it with a little force and it would pop out).
I also replaced both outer tie rods. Oh, and replaced the transmission fluid after it all dumped out when the axel came out.
After I was done I tried driving and there is a horrible grating sort of noise coming from the area of my left front tire. It's like a crowbar on a metal marraca. It's most pronounced when I'm turning left and in gear, but I hear it when I'm drving straight as well, even when I'm not in gear. It follows the speed of the wheels, grind grind grind grind.
Did I maybe screw up the axel (I didn't notice anything wrong with it). Was I supposed to line the axel up a certain way maybe? Maybe I didn't get the axel all the way in, but then wouldn't the tranny fluid dump out after I refilled it? I doubt the problem has anything to do with the outer tie rods.
Oh, also, when I was knocking the cv joint off the axel, I used a piece of wood and the sledge and some splinters got into the ball bearings. I washed it out with brake cleaner and re-lubed it when I put the boot on. I got most everything out of the cv joint except for a few really small splinters wedged by the ball bearings. Could this be the problem?
PLEASE HELP!
Old Aug 10, 2007 | 10:33 PM
Hectic's Avatar
Could be the axle is rubbing against the splash guard. If you can't find the source of the sound, jack the front end up and rotate the wheels and try and track it down. I wouldn't get too worried, but trying to force the axle in with a sledgehammer can't be good. It should go in easy and snap into place.
Old Aug 11, 2007 | 12:14 AM
ColombianMax's Avatar
After reading the title and not reading a SINGLE word of what you typed. I'm gonna have to say, take the axle back out and make sure it goes IN. and that you've got clearance wherever it passes through. Make sure that the ends of the axle arent stripped. good luck with your axle prob
Old Aug 11, 2007 | 12:46 AM
bigdanny's Avatar
does it sound like it's dragging something when you drive slow? my car makes that sound
Old Aug 11, 2007 | 01:58 AM
Greeny's Avatar
¯\(°_o)/¯
Sounds like your d-side wheel bearing is toast.
Old Aug 11, 2007 | 05:48 AM
hoyshnin's Avatar
I guess it could be, but I wasn't having any problems at all before I took out and put back in the axle (and did the other stuff mentioned above). Why would the wheel bearing all of a sudden go out?
Old Aug 11, 2007 | 05:50 AM
hoyshnin's Avatar
I can feel it in the steering wheel, so I don't think it's something like a splash guard.
Should I just get a new axle and replace the whole thing? I'm temped to do this because I want to get places today. Would replacing the axle for sure solve the problem?
Old Aug 11, 2007 | 06:07 AM
hoyshnin's Avatar
No, it's not a dragging sound because it isn't constant. It's like grind grind grind grind. I hear a grind with every rotation of the wheel. It kind of makes me think it's the cv joint?
Old Aug 11, 2007 | 07:36 AM
hoyshnin's Avatar
I figured it out! It is a the speed sensor rubbing up against the ridged metal piece on the cv joint assembly, now I have to figure out how to fix it. The ridged metal piece (sorry, I don't know what it's called), seems to move side to side if I turn the axel really hard (with my hand). It only moves about 1 mm, but because the speed sensor is so close, it's rubbing it. Do I maybe need to screw in my axel nut more to better secure the axle?
Old Aug 11, 2007 | 07:48 AM
goon9's Avatar
Sounds like it to me tooooo
Old Aug 11, 2007 | 09:00 AM
hoyshnin's Avatar
FIXED! I hadn't tightened the axel nut enough (silly me) so the axel was a bit loose side to side and was rubbing up against the abs speed sensor. I tightened down the nut and it's perfect now! Thanks all.
Old Aug 11, 2007 | 09:33 AM
aminus21's Avatar
Glad to know you got it done
Old Aug 11, 2007 | 03:19 PM
Greeny's Avatar
¯\(°_o)/¯
Hence the bad wheel bearing sound..
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
mls277
Aug 11, 2015 07:18 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
