jwt ecu
Old Aug 21, 2007 | 05:38 PM
bigdanny's Avatar
jwt ecu
i was looking up some ecu's at jwt. i found two versions for my vg30e. one said "FED" and one said "CAL" the description for both ecu are exactly the same...
my question is: what is the difference between those two?
Old Aug 21, 2007 | 05:56 PM
pmohr's Avatar
No more Maximas...
Fed spec and Cali spec...
Different emissions stuff, is about it.
Old Aug 21, 2007 | 06:00 PM
bigdanny's Avatar
which one should i get? sorry i'm a noob
Old Aug 21, 2007 | 06:12 PM
pmohr's Avatar
No more Maximas...
Well, is your car Fed spec or Cali...?
Old Aug 21, 2007 | 07:57 PM
Matt93SE's Avatar
STFU n00b!
If you live in Cali and your car is cali spec on the emissions.......
(do some searching around- there's lots of threads on how to tell which your car is).
Old Aug 21, 2007 | 08:12 PM
bigdanny's Avatar
okay... now when i purchase it... what do they give you? like the product... do they give you a chip and you install or do they send you the whole thing to plug into the harness>
Old Aug 21, 2007 | 08:24 PM
Matt93SE's Avatar
STFU n00b!
depends on what you want to do. generally you send them your eCU and they modify it, fitting it with a daughterboard and new ECU.. then they ship it back to you.
OR you pay them a whole lot more money and they use an ECU they have sitting on a shelf.
or you could watch the classifieds here and ebay and you'll see one come up every few months for much cheaper than new.
Old Sep 6, 2007 | 04:13 PM
bigdanny's Avatar
can you use a fed spec ecu on a cal spec maxima?
Old Sep 6, 2007 | 04:24 PM
bigdanny's Avatar
"this vehicle conforms with the US EPA and the state of califonia" is that FED spec or CAL spec?
Old Sep 6, 2007 | 04:35 PM
Greeny's Avatar
¯\(°_o)/¯
"this vehicle conforms with the US EPA and the state of california" is that FED spec or CAL spec?
Ummm..cal spec
Old Sep 6, 2007 | 04:41 PM
Jeff92se's Avatar
I'm needing a caw
How much are these new? $500? The more I think about it, the more I think one could do the same via twisting the dist and using a SAFC. Or an EU that you hardwire in.
Old Sep 6, 2007 | 09:00 PM
Matt93SE's Avatar
STFU n00b!
you would need the EU in order to change many of the things the JWT fiddles with.
it adjusts timing and fuel curves, based on throttle position and engine rpm and etc.
it's more than just advancing the timing and adding more fuel.
Old Sep 7, 2007 | 10:39 AM
Jeff92se's Avatar
I'm needing a caw
The more I think about it, the more I think JWT doesn't fiddle with nearly as much as we would like. IMHO
Old Sep 13, 2007 | 09:00 PM
Matt93SE's Avatar
STFU n00b!
Yup. JWT really didn't do a whole helluvalot with our ECU.
increase timing, bump WOT fuel to 12.5:1 based on MAF voltage.. leave cruising A/F at 14:1.. raise rev limiter a few hundred RPM.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
