the trunk
Old Sep 1, 2007 | 11:44 AM
saxytothemaxima's Avatar
the trunk
Okay well I have a slight issue. My trunk dosnt stay open without me holding it up or it being on a slope.
I have some newer springs for the trunk from my uncles junker neon but I dont see where they go. But I did notice that theres a broken piece. heres a pic of what im talking about.
broken side
fixed side
Old Sep 1, 2007 | 12:43 PM
ustfdes's Avatar
- Product of Maxima.org -
there's a bracket that's missing, In the first picture, the bracket is circled, and in the second, i've circled the two points that the bracket mounts to.
bracket:
bracket mount points:
i'm not too sure as to what the replacement procedures are, but if you have another bracket, you should be able to figure it out pretty easily.
edit: upon inspection of my brackets and trunk mounting setup, it appears you may need the entire lift arm, (as circled in the next picture), unless you drill out the replacement bracket and use a bolt instead.
Old Sep 1, 2007 | 12:44 PM
ustfdes's Avatar
also, if you need another bracket, i'm sure i could pull one off my parts car and get it to you for the cost of shipping plus a couple dollas.
Old Sep 2, 2007 | 09:06 AM
cool thanks.
Im gonna go to the junkyard to the max out there and see if it has the trunk setup. Then Ill pm you about the bracket. thankyou. :]
Old Sep 2, 2007 | 09:44 AM
ustfdes's Avatar
sounds good, no problem!
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
