dash lights
Old Aug 1, 2001 | 07:41 AM
SEguy182's Avatar
Hey i know this is prolly the most redundant thing on here other than putting a turbo on a vg, but i need to know how to get the gauge cluster out, i searched and couldnt find what i needed, but i am changing out my dash lights, i just need to know what comes out, and how hard it is, if anyone could please help i would appreciate it.
Old Aug 1, 2001 | 08:30 AM
Maxirasta's Avatar
hey whats up...I posted the same question a few days ago and Iggus hooked me up..I havent tried it yet (need time) but ill give u what he told me.
"Ok, this actually isn't that hard, at least not once you've gotten used to it, which i've done this about 20times. Also, I'm obviously not sitting in my car right now, and I've taken apart many other car's dashes, so if you're reading what i have written here, and then you're trying to do what I say, and they just don't match, then you can just make a post telling me how stupid i am.
But theres pretty much like 4 screws under by where the steering wheel goes. Then there's 2 under the dash when you look inside of it. Theres a couple more sitting around, you just pretty much have to look around. Then you get the two main plastic pieces off from the dash off, and then there's the main piece which is the part of the dash that contains the Speedo, Tach, etc. take that out, there's like 4 screws or so holding that in. Then you have to look behind the piece, and be careful, because there are some cables (power and computer) that are running into the car and to the piece. Disconnect those, and then you can taker that into your house or whatever and work with it there. Pretty easy from there.
Sorry I didn't go into so much more depth, I had typed this whole thing before, then my computer botched or something, and everything I just typed got erased. IGGUS was not happy. So now here you go. Good luck, they'll look nice."
-IGGUS
Old Aug 1, 2001 | 03:51 PM
MadMaxBrent's Avatar
I found you had to remove the centre console trim to get to two more screws plus it was easier to remove the steering column trim when getting the dash out.
Brent.
mvm062
Nov 30, 2020 09:00 AM
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
Maxima30
Sep 7, 2015 06:13 PM
