Window !!
Old Aug 2, 2001 | 08:18 PM
Maxirasta's Avatar
On my way home from work I was putting my window up when it sounded like it just fell. Now it will go down but it wont go up. I have to push it up by hand. Any suggestions ???
Old Aug 2, 2001 | 08:22 PM
Jon91SE's Avatar
Pusssseeeehhhh
time to get yourself a new window regulator
Old Aug 2, 2001 | 08:23 PM
dmontzsta's Avatar
Ford Only.
Window Regulator!Get ahold of Craig B for his directions or another site.I think you can get em for about $60 now.
Old Aug 2, 2001 | 10:54 PM
Matt93SE's Avatar
STFU n00b!
read the Max FAQs links above. there's tons of info in there.
Old Aug 3, 2001 | 05:07 AM
DaBoxSE's Avatar
Full Moon! That just happened to me this morning too!! Front Passenger side window regulator just snapped on me. Its stuck 2 inches down.
Old Aug 3, 2001 | 10:42 AM
«§»Craig B«§»'s Avatar
99% chance its your window regulator like everyone else has said
you can replace it yourself if you're just a little bit mechanically inclined
instructions are on my site (clikc link in my sig)
Old Aug 3, 2001 | 12:55 PM
DaBoxSE's Avatar
Hey Craig,
I took my door apart today to see what happened and it seem like the the white plastic holder on the window holder broke in to a few pieces. The Regulator cable is intact. But the plastic piece broke, so the little metal guide that is on the cable pushes the window down, but not up. Do I still need a whole new regulator? Or is it possible to be fixed?
Thanks,
|C
Old Aug 3, 2001 | 09:39 PM
Originally posted by DaBoxGTI
Hey Craig,
Thanks,
|C
I think this is what causes the regulator problem. Then after trying to make it go up a few times, the cable will get wrapped around everything and in a big mess. I guess you could try to glue everything back together, but I do'nt know how long that would last. Personally, I'd just buy a new regulator, but you could give that other way a shot
Old Aug 4, 2001 | 07:22 PM
DaBoxSE's Avatar
Nope, no mess with the cable. It rotates perfectly fine and is on track. I guess it wouldnt be possible to just replace the part that is connected to the window, huh? I'm probably gonna have to give courtesy a call..
Old Aug 5, 2001 | 06:21 AM
bobl's Avatar
Different but window related problem
My '90 GXE has a different window problem.
There seems to be some kind of button problem with the drivers side switch. The window will not stay rolled down!
I can hear the switch clicking. If I use the auto-down button, the windows goes down but then goes right back up. The only way I can stop it from going back up is to hold the drivers side button in the down position. This no longer makes the window go down, it just stops it from going up!
AIIIEEE.
Also, this short or whatever seems to be killing my battery. Anybody have any experience with this problem and some idea of the cost to fix it? I'm afraid Nissan is going to want to replace some huge piece that's gonna cost me an arm and a leg.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
