Head Lamp Issue..
Old Aug 8, 2001 | 06:52 PM
TSI-HEC's Avatar
Just Got Home and Noticed Right Front Headlamp Was Out, Replaced with new one. and it DOES NOT LIGHT UP ??
What Can i check ???
91 SE..
TSI HEC NYC
Old Aug 8, 2001 | 09:04 PM
Cincy94Max's Avatar
Fuse, wiring harness, wires, the type of bulb you are using.
Old Aug 8, 2001 | 10:22 PM
MaximaSE91
you need to replace the connector that plugs into the bulb I got twenty dollas that say its melted a bit, replace them with some aftermarket ones from napa the use a thicker gauge wire and are better for higher wattage bulbs.
I replaced both of mine they cooked crispy!!!.
Old Aug 8, 2001 | 11:29 PM
khrfadz's Avatar
what rims are those that u got??? they look nice
Old Jun 3, 2002 | 09:40 AM
TSI-HEC's Avatar
FRONT HEAD LAMP ISSUES
I did checked all those things... replaced bulb but Still front right light only comes on if i Put it on high beams......
HEC TSI NYC
91 SE
Old Jun 3, 2002 | 12:03 PM
jim90gxe's Avatar
Re: FRONT HEAD LAMP ISSUES
HEC TSI NYC
91 SE
wowzers....took you a year to check all those thing??
It's probably the switch on the steering wheel column. I have pretty much the same problem. If I'd flick between low and high a few times the low beam filament thats out would turn on.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
