Lowering Springs - Enough Rubber Clearance???
Old Aug 9, 2001 | 04:51 PM
Shugarhi's Avatar
Hi, im planning on lowering my car with Eibach/tokicos... but the rear of the car is already weighed down from my stereo.... i measured it and the distance from the tire to the wheel well is less than 1.5inches... i have aftermarket tires (225/45/17) and if by somechance my car "tucks rubber" so to speak, will i have any problems with any sort of rubbing from the tires and the wheel well?
Old Aug 9, 2001 | 05:05 PM
Jon91SE's Avatar
Pusssseeeehhhh
Ive got sprints in my car for months now and i tuck rubber on all 4 corners, i have yet to have a rubbing problem or anything, you shouldent have a problem with eibachs, hope i could help.............
Old Aug 10, 2001 | 12:25 PM
Bucktown's Avatar
you won't have any problems. i have 17x7's with 215/45 tires. i used to have eibachs and i have absolutely no problems with rubbing. the tires aren't close to tucking under the fender. the eibachs are stiffer than the stock springs, so your backend won't sag from your stereo. here's a pic of my ride with the eibachs:
http://images.cardomain.com/installs...427_1_full.jpg
Old Aug 10, 2001 | 12:57 PM
Shugarhi's Avatar
thanks bucktown and max, exactly what i wanted to hear, ill post pics when theyre installed
Old Aug 11, 2001 | 02:19 PM
Maximum5spd's Avatar
My opinion do not get Tokicos, I think they are horrible struts, i had them for less then 6 month they lost all the pressure and stiffness, plus theyre making noise on any bumps. DO NOT GET THEM. I suggest Konis but theyre kinda expensive. But hey its your car that's just my $.02.
Old Aug 11, 2001 | 10:40 PM
MaximaSE91
I have 18x7.5in Tantrums and I tuck on all 4 no problems here and im using suspension techniques
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
