Brake Caliper Change
Old Sep 13, 2001 | 07:56 PM
blackandwhite's Avatar
To them I'm like an idol
I just got a great deal on some new calipers. Is the install hard?
Old Sep 13, 2001 | 08:10 PM
Paint also?
I was thinking about painting them. Do I need that special paint? It's expensive, or is their something cheaper that works ok?
Old Sep 13, 2001 | 08:19 PM
JDwyer2821's Avatar
Re: Paint also?
High heat paint at any hardware store will work. The install is not hard if you dont have to bleed the brake fluid. Get a manual if dont have one
Old Sep 13, 2001 | 08:44 PM
Matt93SE's Avatar
STFU n00b!
Uhhh, CHANGING calipers requires disconnecting the brake lines... yeah, you'll have to bleed them..
if they're just stock calipers, changing each side is about a 10 minute job for me. no big deal. the longest part of things are pulling and mounting wheels.
Old Sep 14, 2001 | 01:07 AM
JDwyer2821's Avatar
I did not need to bleed mine. I claped the hose as close as possible to the caliper and let no air in. It was a fast switch but easy. I geuss I got lucky
Old Sep 14, 2001 | 06:52 AM
Matt93SE's Avatar
STFU n00b!
go ahead and bleed your lines.. it takes 20 minutes. I promise you'll see a difference.
Old Sep 14, 2001 | 06:58 AM
Bleed?
How do you bleed them? Just take the brake fluid cap off? Or is there a relief valve somewhere?
Old Sep 14, 2001 | 07:30 AM
Matt93SE's Avatar
STFU n00b!
there's a bleeder screw on the caliper... you'll need a pice of clear hose and a jar to hold the old fluid (you can buy a kit with everything you'll need from any parts store for about $4.)..
suck out all the old fluid out of your master cylinder and fill with fresh fluid.. connect the bleeder hose to the caliper and open and reclose the bleeder screw.. (just so you know it'll open.).. I also suggest dabbing some thick grease on the threads to keep any air from getting sucked back in through the threads.
Now have one person pump the brake pedal 5-6 times, then hold it down the last time.. open the bleeder screw and let the fluid out until it stops flowing.. close the bleeder screw and repeat. you'll have to do this 10-15 times on the right rear caliper because the lines are so long. on the others, it'll take less time (10 on the left rear, 6-7 on the right front, 4-5 on the left front) just because of the length of tubing between each of them.
You'll know you're done when you see the new fluid come out the hose.. most likely the fluid you have in there will be dark brown or black if you've never changed it. new stuff will be a bright gold or blue color, depending on brand. (some brands make a blue and yellow, so it'll be obvious when you've got new fluid flushed through the system).
be sure to check the master cylinder fluid level several times.. (about every 5-6 "bleeds"), as you'll need to fill it up several times before you're done.
the order to bleed each caliper is:
right rear
left rear
right front
left front
.... When you're done, start the car (don't put in gear yet!) and press the brake pedal several times.. it'll probably go all the way tot the floor the first time or two, but should soon get back to normal height.. if it's firm on the first push, that's fine..
NOW put your car in gear and slowly roll forward or back and test the brakes.. if everything looks fine, go for an easy drive and check things out. don't just haul *** down the street and HOPE your brakes work at the end. I know three people from the board who were stupid enough to do that, and their cars are now in a junkyard. (of course they were stupid enough not to refill their master cylinder!)
it's long, but not difficult.
Old Sep 14, 2001 | 08:19 AM
HoJo's Avatar
Everything matt said, I would also suggest going to autozone, or something, and getting a Haynes manuel. They will go through how to take the calapers off and put them back on.
Old Sep 14, 2001 | 02:06 PM
jim90gxe's Avatar
go here: http://www.cybrrpartspro.com/Chilton...61CH09_13.HTML for exploded views of brake capliers
Old Sep 14, 2001 | 02:09 PM
Matt93SE's Avatar
STFU n00b!
They're not hard.. just pull the wheel off and grab a 17mm wrench and start turning.
Old Sep 14, 2001 | 02:11 PM
Books
Thanks Matt (and everyone else)
I already have a Haynes and a Chilton for my car
Old Sep 14, 2001 | 02:22 PM
Matt93SE's Avatar
STFU n00b!
Okay, so you had all the information you needed right there the whole time? hmmmmmmmm
Old Sep 14, 2001 | 02:25 PM
Jeff92se's Avatar
I'm needing a caw
What a pain, two people, refilling m/s fluid. sheesh! Hell I didn't even take my wheels off! muhahahhaha!
right rear
left rear
right front
left front
Old Jun 13, 2006 | 12:30 PM
blackmax42's Avatar
A one person way..?
When I bled the brakes there was no "helper" available. I basically used the method above but with a slight variation. It might sound absurd but after I pumped the pedal, I then used the power seat to wedge a board between the brake pedal and the seat, to keep the pedal depressed. Then I got out and I opened the bleed valve. Pain in the butt however, it worked just fine. Hope this helps the helperless guys out there!
Old Jun 13, 2006 | 12:36 PM
Jeff92se's Avatar
I'm needing a caw
I'm deciding if I should ban you for grave digging.
Old Jun 13, 2006 | 12:37 PM
Greeny's Avatar
¯\(°_o)/¯
WTF!...You exhumed a 5 yr old thread to tell us this????
Old Jun 13, 2006 | 01:00 PM
Mizeree_X's Avatar
Getting back to his roots
Uhhh, they sell 1-man bleeder kits for less than $10. Much easier and less ghetto than that.
Old Jun 14, 2006 | 01:06 PM
blackmax42's Avatar
Very sorry to those I offended with my post. Just trying to help someone out there who like me, couldn't get a one-man bleeder kit beforehand, and was wondering how to keep the brake pedal depressed.
Old Jun 14, 2006 | 07:23 PM
Greeny's Avatar
¯\(°_o)/¯
Aww **** guys,lets let this fucker die again......
Old Jun 15, 2006 | 08:34 PM
HoJo's Avatar
Talk about an old post
Old Jun 16, 2006 | 01:14 PM
Matt93SE's Avatar
STFU n00b!
HOWIE!!
Talk about an OG dropping in out of the blue!
Old Jun 16, 2006 | 01:33 PM
Darkwing48's Avatar
I noticed that the thread pages don't go beyond or to 10. So no one could know that this is an old thread. Give him a break.
Hey why is that "the way it is"?
Old threads wouldn't be revive if the informational thread can be archived and retrieved. Cmon, has about learned about database management? (no offense)
Old Jun 16, 2006 | 01:35 PM
Matt93SE's Avatar
STFU n00b!
Ummm, before you can reply to a thread, you have to at least SEE it. which means the post dates are stamped all over it.
Old Jun 16, 2006 | 01:45 PM
Greeny's Avatar
¯\(°_o)/¯
Is this old fart of a thread gonna die????????????????????????????????????
Oh well,Good whoring thread anyhoo...
Old Jun 16, 2006 | 01:59 PM
Darkwing48's Avatar
Oh I see. Thanks. Ok this is the last time I will respond to this thread.
Old Jun 23, 2006 | 06:01 PM
Will's Avatar
Hahahahahahaha.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
