Power Lock Problem
Old Sep 14, 2001 | 04:52 AM
clemtig
The power locks on my 93 SE have quit working. I can a clicking noise, but the locks will not raise or lower. Does anyone know how to fix the problem?
Old Sep 14, 2001 | 07:19 AM
«§»Craig B«§»'s Avatar
most likely problem is your door lock timer
this is the cause of probably 90% or more of door lock troubles
you can replace it for $60 or so with a new part or if you have some electrical knowledge, you can take it apart and resolder all the joints with some flux and that usually cures it
if you dont want to do either of those either because you dont have time or dont know how to solder, contact Matt93SE and he'll fix it for you and return it for a small price
I could do it for you too, but I dont want to take business away from Matt since he is the one who told me how to fix it
Old Sep 14, 2001 | 09:16 AM
JDwyer2821's Avatar
I jut went out and bought the timer. It is quite easy to fix
Old Sep 14, 2001 | 10:21 AM
Aaron92SE's Avatar
NWP Engineering.com
I am having the same problem to. I think I am going to try to resolder some parts that looked burnt. If that doesn't work .. Courtesy Nissan, I hear is the cheapest.
Old Sep 22, 2001 | 08:51 PM
lateralus's Avatar
p/w locks work from inside, but not outside
When I try to lock all 4 doors from outside(using key) only the driver side will lock. It used to lock all 4 doors. Does this also fall in the same category of possible fixes? thanks.
90se
Old Sep 22, 2001 | 08:58 PM
djslinkyz's Avatar
Re: p/w locks work from inside, but not outside
90se
yes
lowpost99
Oct 26, 2025 06:53 PM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
