3rd Gen Turbo?
Old Sep 25, 2001 | 10:15 PM
  #81
MaxTypeR's Avatar
Re: Disappointment....
Originally posted by Czar
I took my car to the track for the first time since the 'manifold probs', and lets say that it was not what I had expected (I was cocky enough to bring a helmet 'just in case' I broke out of 14's).
Anyways I got 2 15.1s and 2 15.6s. I had to let off everytime except
bahahahaha just wait till i get my supercharger. i will break 14s and beat ur slow poor excuse for a turbo maxima.
Old Sep 25, 2001 | 10:21 PM
  #82
TB-MaxSE-89's Avatar
Re: Re: Disappointment....
what is a FPR and a FMU?
Old Sep 25, 2001 | 10:36 PM
  #83
Czar's Avatar
The funny thing is that even with my car in its pitiful state, its still faster than yours... And BTW before I did all this I was running 14.8s....
Old Sep 26, 2001 | 07:09 AM
  #84
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Re: Re: Disappointment....
I know FPR= fuel pressure regulator and FMU=?
Old Sep 26, 2001 | 10:39 AM
  #85
DaBoxSE's Avatar
First you need to get your own Maxima.
Old Sep 26, 2001 | 12:53 PM
  #86
Nismo87SE's Avatar
FPR = Fuel pressure regulator, FMU = Fuel management Unit. I believe the FPR will allow one to increase or decrease the fuel pressure from stock. So you either run slightly/way rich/lean. The FMU allows you to increase the fuel pressure proprionatly (sp?) to boost level. For example Czar says he has detonation at high rpm. With the FMU he would be able to run a richer mixture at high rpm without running way to rich in the midrange. If he had a BTM (boost timing master) he could set it to retard the timing by a set amount of degree's per PSI of boost.
Old Sep 26, 2001 | 01:10 PM
  #87
DA-MAX's Avatar
Nismo, CZar--->
have you seen the new MSD 7 Programmable-->
MSD 7(programmable):
http://www.msdignition.com/2000_1.htm
not sure of its compatibility with DIS vehicles, but it basically allows ignition mapping along the RPM range and is programmable by computer or handheld unit. Damn the VE and its 6 coil packs, if you were a 4cyl. with 2 packs you could get this one and be done with it!!-->
http://www.msdignition.com/n2000j.htm
BkGreen97
Apr 2, 2016 05:47 AM
pears
Sep 18, 2015 05:25 AM
A32goldylocks
Sep 14, 2015 06:49 PM
