Rewire Interior Lights...
Old Oct 29, 2000 | 11:19 AM
JeffesonM's Avatar
living out of a maxima...
I'm looking to wire interior lights (doors, dome) to some kind of switch. Does anyone have any suggestions, like an easy place to get to that circut?
Old Oct 29, 2000 | 11:35 AM
Blu Max's Avatar
yeah i wanted to do this too.
It'd be cool to turn the door lights on when you what w/out opening the door. The best thing i can think of is a relay w/ a switch, so you can trick the system into thinking the door is open, i can do it but i have to think of a way to wire the relay correctly( don't like trial and error when it comes to electrical wires). The trick is finding a place to put a switch, idont want to drill holes in my car.
Old Oct 29, 2000 | 11:52 AM
JeffesonM's Avatar
I know there are little buttons at the bottom of the front doors which sense if they're open. Don't know where the ones are for the back. Either way, I figure they all have to connect together somewhere and hook up to a positive. If I knew where that was, I could sneak a wire in between there. I'm thinking of taking out that change holder next to the [power-a/t-comfort] thingy and mounting the switch in that hole. Maybe someone around here has a wiring diagram or repair manual, they might have more info...
Old Oct 29, 2000 | 04:59 PM
vmarques82's Avatar
rear switches
the rear switches are in the same location.
I found a really nice place to mount switches.
I hve my switches for neons mounted in a little enclosurein the center console armrest since there is lil room in there
Old Oct 29, 2000 | 10:57 PM
kingston's Avatar
ummm don't hook up the wire to a positive otherwise you might short something. The way most japanese interior lights work is by putting ground onto the door trigger wire like some alarms do when you disarm it. The lights will turn on as a courtesy light. Anyhow, if you guys want cruising lights, just add your own. Under the seat or under the dash. Good luck with tapping into the door trigger wires.
Old Oct 30, 2000 | 09:38 PM
JeffesonM's Avatar
No, I'm looking for more of the 'stealth mode' effect. I guess I'll have to try fishin' for wires...
Old Oct 31, 2000 | 11:55 AM
DDD
Door lights switch
It's not necessary to find the common point of all the door buttons. It's enough to install an additional switch "in parallel" with the button on the driver's door, and you can turn ALL of the door lights with that switch.
Good luck,
DDD
Fbana41
Aug 29, 2016 12:18 PM
Sir Tilus
Mar 22, 2016 01:49 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
GregL65
Sep 7, 2015 10:33 PM
