Where can I buy muffler bearings for my car??
Old Sep 25, 2001 | 01:18 PM
Jeff92se's Avatar
I'm needing a caw
I hear the sealed type make the exhaust roll smoother and thus more powah!
NSK?
Old Sep 25, 2001 | 01:36 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Where can I buy muffler bearings for my car??
Jeff I swear how many time do I have to tell you....upgrade your O-pipe before you even think about doing the muffler bearings....GEEEZ!!
NSK?
James92SE's Avatar
2 VE's are better than one!
Hmmm......I'm sure lot's of people know the answer to this one. I'm not quite sure where to get the muffler bearings. I'll wait for someone with more knowledge to post.
Old Sep 25, 2001 | 01:41 PM
maxmizd27's Avatar
You can get them from BS Racing. They also carry that silicone blinker fluid, synthetic spark plug oil, muffler belts, tropsy rods and fratistats. Be sure to check out their new line of finnishing products too. They make great emery sparks! Happy Shopping.
Old Sep 25, 2001 | 01:49 PM
James92SE's Avatar
Didnt MaxTypeR get his car built up by BS Racing?
Old Sep 25, 2001 | 01:55 PM
maxmizd27's Avatar
I think that's where most of the Honduh kiddies go.
Old Sep 25, 2001 | 02:00 PM
Jeff92se's Avatar
I'm needing a caw
That was built by "Team Ignorance".
Old Sep 25, 2001 | 02:27 PM
Lordrandall's Avatar
Damn, I just broke my BOV speaker.....
Old Sep 25, 2001 | 02:33 PM
LeeIt2Me's Avatar
Just replace my Stock muffler bearing with a turbo muffler bearing. WOW!!!. what difference. I think I gain like 50 more brute drunken horse power...
Old Sep 25, 2001 | 02:34 PM
«§»Craig B«§»'s Avatar
it's on my page in the how-to with pics
Old Sep 25, 2001 | 02:38 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Old Sep 25, 2001 | 02:47 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i have some muffler bearings if you want them jeff
Old Sep 25, 2001 | 03:11 PM
dmontzsta's Avatar
Ford Only.
Everything is on Craig's page.
Old Sep 25, 2001 | 07:24 PM
maxmizd27's Avatar
Yea, but are they the triple gold kind?
Old Sep 25, 2001 | 07:27 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Sep 25, 2001 | 08:46 PM
DanNY's Avatar
Ad·min·is·tra·tor
NSK?
after a long search Jeff....
http://www.kalecoauto.com/
features
Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right? That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCo muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers. Also works well on heavy duty exhaust systems. One per muffler.
you're welcome
Old Sep 25, 2001 | 10:39 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: Where can I buy muffler bearings for my car??
you're welcome
i still wanna get an O-pipe damnit!
Old Sep 26, 2001 | 06:34 AM
maxmizd27's Avatar
Just don't forget to get an O-pipe big enough to handle the wattage of your intake amplifier. Just a little friendly advice.
Old Sep 26, 2001 | 11:57 AM
Jeff92se's Avatar
I'm needing a caw
I just found it, at the same place that sells the tornado turbo charger.
Old Sep 26, 2001 | 01:29 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
thanks for the suggestion
Old Sep 26, 2001 | 01:35 PM
DA-MAX's Avatar
MUHAHAHAHAHA........
Old Sep 27, 2001 | 08:36 PM
Pervis Anathema's Avatar
Also, you will want to get some purfied racing air and polyurethane radiator bushings.
Old Sep 27, 2001 | 08:41 PM
dnas420's Avatar
here
try http://www.racesearch.com (enjoy)
Old Sep 28, 2001 | 08:15 AM
hova90se's Avatar
Re: here
If you guys really want some more power, thats really cheap, then take your cat completely off. You will be pleased with the results and the exhaust note, especially if you have a performance exhaust. Just make sure that you don't have to go through inspections in your state.
Old Sep 28, 2001 | 08:41 AM
NYCe MaXiMa's Avatar
I got mine custom fabricated
An alloy blend of metal and plastic coathangers with a drop of aluminum foil. Super durable.
If you want I'll hook you up with the #.
Old Sep 29, 2001 | 12:20 AM
maximum810's Avatar
damn...
You all need to be careful with those mods...might burn up your altenator clutch!
Old Jul 24, 2002 | 08:30 AM
95maxrider's Avatar
Lightly modded
NSK?
the same place i bought my debigulating refibilator
Old Jul 24, 2002 | 09:20 AM
Maxima_Van_WA's Avatar
Why are you worried about muffler bearings? That should be last on your list of mods. The #1 mod for any car enthusiast should be the distributor throw-out bearing, then the next item should be the inline lower heater duct water return line.
Old Jul 24, 2002 | 10:26 AM
maxmizd27's Avatar
You gotta watch out for those things though. I heard they're bad for your coniflin pin.
Old Jul 24, 2002 | 10:38 AM
DaBoxSE's Avatar
what about the power steering bypass blowoff valve container? mad powa!
Old Jul 24, 2002 | 10:44 AM
maxmizd27's Avatar
Yea, but just hope you have the front wheels pointed straight.
Old Jul 24, 2002 | 11:20 AM
Jeff92se's Avatar
I'm needing a caw
Damn you people!
Old Jul 24, 2002 | 12:14 PM
maxmizd27's Avatar
Damn you people!
Oh, I got a million of them.
Old Jul 24, 2002 | 02:14 PM
Don't forget purified racing air and urethane radiator bushings.
Old Jul 24, 2002 | 02:15 PM
Kenny's89SE's Avatar
My favorite is the blinker fluid...best invention ever made.
Old Jul 24, 2002 | 02:50 PM
Gotta have x-drilled brake lines!
Old Jul 24, 2002 | 11:35 PM
pmb1985's Avatar
jeff did you use the SEARCH function???
Old Jul 25, 2002 | 07:34 PM
Z's Avatar
Z
I upgraded my piston return springs last week and it gave me at least 30hp, almost as much as my Vtec sticker.
Old Jul 25, 2002 | 07:44 PM
maxmizd27's Avatar
We need to write our OWN service manual with this stuff.
Old Jul 26, 2002 | 11:17 AM
babbsrw
Make sure you use relative bearing grease when you replace any bearing. You can find it at any boat store.
Lakersallday24
Jun 16, 2019 01:35 AM
erictown
Aug 20, 2015 08:01 AM
BGTONIO1991
Aug 11, 2015 07:38 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
