What are the easiest Hella / PIAA driving lamps to replace existing fogs in a '89SE
I want to upgrade the existing stock fog lamps in my '89SE, but didn't see any prior postings. So I'll ask now....
I'd like to install a set of Hella FF50 or FF75 that have a single-bolt mount. Is this an easy replacement (meaning no drilling)?
Or should I consider something with a two-bolt mount, such as the PIAA 001x or 002x (will it fit into the existing bolt pattern)?
I don't want to spend over $100 on lamps. The Hella's are reasonably priced at $75 a pair. Plus I'm using the existing harness and connections. I'm just going to splice in to the wiring and use the existing switch.
Any help is appreciated.....thanks guys!!!
Re: What are the easiest Hella / PIAA driving lamps to replace existing fogs in a '89SE
03VQMAX
10-02-2016 09:36 AM
MikesChevelle
08-06-2015 11:36 AM
