New Exhaust Studs
Old Oct 5, 2001 | 07:01 AM
vg92's Avatar
New Exhaust Studs
All,
I just received my front pipe, gaskets, studs, bolts and nuts for my 92 GXE. There are total of 6 double threaded studs with nuts for coupling the pipe to the manifolds, and 2 hex bolts for mating to the CAT converter. Are these correct parts? I'm a little suspecious b/c the ones on my existing pipe look different. Also, any advice for removing the old pipe especially the rusted studs will be greatly appreciated.
.Dennis
Old Oct 5, 2001 | 07:13 AM
Matt93SE's Avatar
STFU n00b!
Here's the correct parts you need.
when removing the old studs, spray them well before hand with a liquid wrench type stuff.. if nothing else, WD-40 will help over nothing. let is sit about 30 minutes, then spray again.. wait about 10 minutes then start pulling studs off...
i.e. when you start the job, just spray 'em down, then keep doing it every half hour until you get to the studs.
Old Oct 5, 2001 | 07:26 AM
DanNY's Avatar
Ad·min·is·tra·tor
don't forget to pray before you pull each stud out.
Old Oct 5, 2001 | 11:03 AM
vg92's Avatar
Are these for the SE engine? The part numbers don't match with mine. I got shinny metal gaskets! There's no washers either. Wish I have a digital cam so I can post a picture.
Thanks,
Dennis
Old Oct 5, 2001 | 11:32 AM
Matt93SE's Avatar
STFU n00b!
No, those are for the VG. (I used to have a 93GXE, for which I bought those studs).
those ARE the correct parts, as that's the second set I bought and everything worked.
If the studs themselves don't say "turbo" on the package, then they're probably the old VG studs, which will break again. the "new" studs are the ones for a turbo Z, which are much stronger than the original ones on our car. (thus, nissan HAS noted the studs breaking on 3rd gen Maximas is a problem and has done this much to correct it.).
If your dealer gave you the wrong parts, you should tell them to update their parts computers and read their tech service bulletins (TSB) again.. This problem was noted and supposedly fixed several years ago.
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 26, 2015 05:20 AM
