interior 91 maxima
hehe check out my thread on painted interior...what vents exactly do you want to paint
they're all pretty easy except for the one on the far right passenger side, omg was that a ***** and a half. for the drivers side and surrounding, remove the lower dash, column around the wheel, the piece right behind it, then the bevel around the radio and shifter. then you can take off the piece at the top with the vents. for the far right, since i had everything apart i just loosened the top vinyl section of the dash, take out the glove box and then you can get the right vent out. three screws and its really hard to work in there.
good luck
good luck
basically i just want to paint all the vents in the front, such as the passenger, driver and ones in the middle, also defroster in front, i will probably do some other things too, the pictures look sweet of your ride with that red, any special kind of paint to use, such as brand or style?
mmm well i just krylon for the real paint, do not use cloth paint, its too watery, vinly paint may work as well, didn't test it. any old primer and the clear coat are a must
Slamrod
04-10-2016 05:24 PM
MAXSE5SPD
08-23-2015 12:06 PM
