Gas Mileage
Old Oct 9, 2001 | 07:20 AM
BeatJunky's Avatar
Gas Mileage
If our cars hold 18.5 gallons of gas and consume an estimated 19 mpg City... Why did my car even barely reach 210 miles on a full tank of gas?
18.5 x 19 = 351.5 miles
Whats gives?
Old Oct 9, 2001 | 08:15 AM
raceraver's Avatar
b/c of this
i dunno why but i figured out i got 16.5 gallons... i had my light on completly for like 20 miles... and filled up.. it 16.26 gallons..And i filled when i had exactly half a tank and it was 8.25 gallons then.. So you have 16.5. And u should try and get a new fuel filter ($6), air filter($15 for a cheap one) and plugs($15-20 at the most) (and all that isn't performance). I did that and my mpg went from about 14 to 18.5.. still need to get some injectors.
Old Oct 9, 2001 | 07:46 PM
Tom's Avatar
Tom
I don't know where you live or how you drive (city/hwy), but your O2 sensor might need replacement. I can usually get 25 MPG mixed city/hwy driving in Seattle. High 20's, even 30 MPG is doable if it's mostly highway.
Old Oct 10, 2001 | 09:34 AM
wiseguy's Avatar
My mileage sounds like what Tom is getting, close to 30MPG.
Not sure how they get such decent MPG out of such a big
car, but they got something right.
I'd say, bad injectors (check the resistance across the leads,
they should be around 11 ohms I think...my MPG when to s**t
when my injectors started crapping out), bad plugs, or bad O2
sensor.
Old Oct 10, 2001 | 10:29 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
hey guys......
just thought I'd share this--->
after talking with my firend at emmission, I found out that my gas cap was faulty(being since it failed the gas cap test), he informed me that bad MPG is a result of this....So today I got my new gas cap from Nissan, immediately I could tell the difference as I screwed it in, the seal was WAAAAAAAAY tighter than my old cap, next I took the car for a spin(about 20+ miles), with a 1/4th tank of gas, WOT'd it most of the way and did some regular stop and go traffic in the city with "P" mode on....now usually after a "brisk" drive like this, my fuel gauge would be down to the 1/8th point or less when I got home, but surpirisingly it was still holding strong and actually rose a little above the 1/4th point. tommorow I'm gonna run it down to "E", fill it up again and hopefully get out of the 220-240 MPG range and into the 300s again...just thought I'd share, I always thought, bad MPG automatically = bad injectors, but $16 I'm hoping the gas cap was the culprit!!
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
