gas
Re: gas
Originally posted by markmaxima
i have a question for the experts, what is the best gas to use in a 3rd generation? meaning Amoco, exxon, sunoco? and what octane can we use meaning 89,91,93. i am just curious.
I always just use the cheapest 87 Octane that I can find. If a name brand is the cheapest then I will buy it, otherwise "Racetrack" and whatever else is CHEAP get's my $$. I one time accidently filled my car up with 93, and there was NO advantage that I could see. Basically from what I understand the VG30E is designed to run on 87 octane, and anything higher is just a waste of money. This is a TOTALLY different story if you have a turbo charged car or if your motor has carbon build up, increased compression, or advanced timing. Fortunatly, mine doesn't seem to have any problems with carbon build up (yes, even with cheap gas). The plugs that were probably 100k miles old (85k from the previous owner, 15k miles from me and cheap gas) were worn normally and had NO deposits on them. So IMHO, as long as the cheap gas stations are actually selling you OK gas, then 87 Octane from cheap-o stations should be just fine for our cars. (Unless you have the VE30DE, in which case you NEED 93) I mean, no offense but there is really nothing high stress about a 3.0L V6 putting out 160hp, they don't rev that high, and the compression ratio isn't that high either... why bother unless your car has a known issue?
Just my $0.02, flame suit on :-)
I think for SE's they recommend 91 oct.
When gas was real cheap all I ran was 93.
Don't really see 91 in my area.
Then prices went real high and I did one tank 93 one tank 89.
I do think 93 makes a difference in performance in my VE.
ef9
Oct 4, 2015 08:43 AM
or those places that obviously look run down
and octane boost whenever i go racing
