dont know if this is a transmission problem
Old Sep 17, 2007 | 07:29 AM
Brooklyn Legend's Avatar
I recently started to notice that sometimes when Im stopped at a light, and begin to take off I will press on the gas and the engine will just rev and then start to move but with a jolt. I also noticed in slow traffic if I come to a stop I will feel the bottom of the car move as if the tranny went into a nother gear or something. I checked the fluid its bright red and no leaks to my knowledge. Is this a sign of a dying tranny? The car is a 92 Se auto.
Thanks for any input
Old Sep 17, 2007 | 07:38 AM
redwood_usa's Avatar
Check your mount first.
Old Sep 17, 2007 | 10:52 AM
internetautomar's Avatar
mod or sell?
I'd check the mount, the trans fluid level, and then your bank account.
Old Sep 17, 2007 | 01:21 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well downshifts can be felt... if you are slowing down and your engine is at idle speed and you keep slowing down, it will kick down a gear to keep the RPM at or above idle. so you can feel it, especially at about 6mph when it kicks back to 1st. as for the other thing, yeah the mounts, but also, as your shifter adjusted properly? is there any chance that it's slamming from neutral to drive? just a thought, but the mounts are more likely.
Old Sep 17, 2007 | 04:17 PM
bigb007's Avatar
I had a similar problem a few days ago. When accelerating from a stop, the car would jolt forward. Also shifts were very rough. It ended up being one of the motor mounts that had broken.
Old Sep 18, 2007 | 10:22 PM
Deridex's Avatar
Pshhh. I've been driving without a reverse for like 5 months now. Only "Drive" works, and it feels like it's stuck on 3rd gear since it accelerates really slow but gets to 60 mps on the highway. Auto trasmissin on this car is crap.
Old Sep 20, 2007 | 09:01 AM
MissingNAxion's Avatar
Noob wanting more
true. When i have to go forward in my car, i have to go past drive all the way to 2nd gear and THEN go back up. If i o straight to Drive, it acts like it is in neutral. This is the same w/ every gear. I can barely get it to go into 1st gear. I have noticed also that i hae that jolt also, but i dont think i am getting the same thing you are.Mine just takes a split second to get going.
Old Sep 20, 2007 | 09:58 AM
mod or sell?
sounds like you are in need of a shifter bushing
Old Sep 22, 2007 | 01:01 PM
Deridex's Avatar
What's shifter bushing? Don't mind the question, I've only just started taking interest in actually going under the hood myself.
Old Sep 22, 2007 | 07:13 PM
mod or sell?
at the end of the shifter linkage there is a little plastic bushing that gets worn out and causes the shifter positions to be a bit off.
Old Sep 22, 2007 | 08:15 PM
your transmission is in failsafe mode. it is stuck in 3rd. and i think that's because reverse is broken, it's being on the safe side.
Old Sep 22, 2007 | 09:11 PM
Deridex's Avatar
Ahh, guess shifter bushing won't help me then. As for the fail safe mode, I don't suppose there's a way to override it? Not that I really need to, but it would be nice to at least have a 1st gear again, even with no reverse.
Old Sep 23, 2007 | 07:43 AM
1992GXE's Avatar
yeah dude, thats probably your tranny going bad. mine just recently started doing that, i have reverse and 1st thats it. should be getting it fixed in the next two weeks...good luck with getting it fixed
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
