Speakers for front doors.
Old Sep 24, 2007 | 10:16 PM
helps
After having my stereo deck, amp and speakers stolen
i was putting in new speakers and i realized, how in the hell
am i supposed to put new speakers in my front doors. I guess i could mount
6x9's to the door panel but wouldn't they work loose?
anyone done anything like installing this?
Old Sep 24, 2007 | 10:22 PM
AscendantMax's Avatar
make some baffles out of MDF. basic idea is to make a wooden baffle that bolts up to the stock mounting points, and then the new speaker is then bolted onto that.
the 3rd gen doors are easy to work with IMO. i had similar mounts made for my 3rd gen.
Old Sep 24, 2007 | 10:23 PM
helps
just like a border around where the old one went? and what size did you stick in?
Old Sep 25, 2007 | 04:30 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=388371
Old Sep 25, 2007 | 07:53 AM
internetautomar's Avatar
mod or sell?
my ghetto brackets:
Old Sep 25, 2007 | 12:46 PM
helps
thanks im making 2 outta some old clipboards
Old Sep 25, 2007 | 01:14 PM
eh, clipboards....guess that'll work....but i rather have them made outa 3/4" MDF. it'll provide an additional 3/4" of speaker depth. so no worries of the magnet hitting the window when they're rolled down.
i used some boston acoustics 6.5s in the front doors when i was still driving my 3rd gen.
Old Sep 25, 2007 | 09:55 PM
helps
think there is a way to make it for 6x9's or does it have to be 6.5's
Old Sep 25, 2007 | 10:37 PM
Cliff Clavin's Avatar
Way out West
6.5s are a way better speaker to put in there.
Down the road if you want to upgrade to components, the work is done for you.
IIRC, MrGone used a dremel and cut up the stock Bose mount and fit a 6.5 in the front. That would be a very cheap way to do it.
Old Sep 25, 2007 | 11:13 PM
Matt93SE's Avatar
STFU n00b!
my ghetto job...
Old Sep 26, 2007 | 04:44 PM
Deridex's Avatar
Originally Posted by Matt93SE
my ghetto job...
That actually looks pretty good. And I see you got an aluminum dash kit. Good stuff.
Old Sep 26, 2007 | 07:17 PM
nForce's Avatar
The Computer Guy
Old Sep 27, 2007 | 12:01 AM
^ didn't i sell you those? they were my old baffles i got from james92se.
Old Sep 27, 2007 | 09:06 AM
rmdl51's Avatar
White_Shadow
I have the ones from ebay:
http://cgi.ebay.com/ebaymotors/Front...mZ330089670884
Those are ok, i mean they do the job if don't have time to work with MDF and make your owns.
I also recommend to go with 6.5". If you can invest in a good set of components you'll get a very good sound. If I'm able to open my door panel this weekend I'll post some pictures for you.
Old Sep 27, 2007 | 12:33 PM
nForce's Avatar
The Computer Guy
haha yea you did
Old Oct 8, 2007 | 09:43 AM
whitemax89's Avatar
the 6.5 uses the same wattage and everything it wont burn the wires or mess up the fuses ....etc
Old Oct 8, 2007 | 02:28 PM
bigb007's Avatar
Question
If I were to upgrade to components, where would be a good place to mount the crossovers? Is there a convenient place in the door?
Old Oct 8, 2007 | 08:01 PM
sanford7575's Avatar
I replaced my whole entire system because I had a problem with the Bose in my '92 SE. I chose to mount my new front speakers on the kick panels right by the driver and passengers's feet. It's much easier to run new speaker wire to the amps in my trunk.
All my other components are in the trunk as well.
wyobbagy
Jan 3, 2023 12:03 PM
9aj9
Apr 5, 2020 12:11 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
