Weeping oil
Old Oct 29, 2007 | 09:57 AM
tucker's Avatar
Weeping oil
Gents,
I'm leaking oil around the valve cover gaskets and dipstick. Someone suggested clogged PCV valve. What does everyone think??
Old Oct 29, 2007 | 10:32 AM
traxtar944's Avatar
Would be lost w/out the org
I'm thinking you just need to replace your valve cover gaskets. Eventually they all leak...it's a given for a 100,000+ mileage engine.
edit: Shameless plug for my FS thread...take a look at my sig
Last edited by traxtar944; Oct 29, 2007 at 05:48 PM. Reason: shameless plug for my FS thread
Old Oct 29, 2007 | 04:07 PM
ColombianMax's Avatar
Indeed, I'm gonna have to say Valve Cover gaskets as well UNLESS you got pics to better help with your description. If you suspect its a PCV valve then why dont you go to the parts store and pick one up, its only $4.99 and it takes 5 minutes to change. 30 if you have crappy tools like I did my first time and use pliers lol
Old Oct 29, 2007 | 06:12 PM
Tquick's Avatar
If it is indeed leaking around the dipstick, and not just dripping there from the valve covers, then I would go with the PCV valve, or the hose connected to it. If that is the case, you will probably need to replace the valve cover gaskets as well anyway, because the same positive pressure that will push oil out the dipstick will push oil out the valve covers, and compromise their seal.
Old Oct 30, 2007 | 09:29 AM
92 Max's Avatar
What engine do you have?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
