Gas tank
Old Nov 3, 2007 | 01:25 AM
Deridex's Avatar
Gas tank
Is there a way to drain a gas tank without removing or puncturing it? I couldn't see anything resembling a drain.
Old Nov 3, 2007 | 09:30 AM
Pearl93VE's Avatar
I can has?
There's always one way...
Old Nov 3, 2007 | 10:14 AM
redwood_usa's Avatar
Remove the left rear tire. there is a vent hose that can be removed (remove clip). then put a siphon in thetank and siphon out all the gas.
http://www.courtesyparts.com/betasit...1627_1631.html
see part 17226 , just above the arrow that says front
Old Nov 3, 2007 | 10:19 AM
sublunary's Avatar
or you can remove the back seat, pull out fuel pump and siphon there which has the advantage of being able to see that you have emptied the tank completely
Old Nov 3, 2007 | 11:09 AM
Deridex's Avatar
Hey, that's a hose that was leaking a while back. Everytime I parked on a slight slope, I'd come back and see a puddle under the car. I sealed it with some vinyl tape.
Both of these methods require a siphon. Guess I gotta go buy me a siphon.
Old Nov 3, 2007 | 11:27 AM
Dhunterx's Avatar
If you're gonna remove the hose, replace it.
Old Nov 3, 2007 | 12:15 PM
Deridex's Avatar
Yeah, that's probably a good idea in this case.
Old Nov 4, 2007 | 02:55 AM
maximagician's Avatar
disconnect the fuel filter and route the feed line to a container and turn the key to "on" position letting the fuel preesure do the work
Old Nov 4, 2007 | 08:31 AM
sublunary's Avatar
its not good to run your fuel pump dry so i would be cautious with that. if you have to get the tank completely empty you will still need the siphon.
Old Nov 4, 2007 | 08:45 AM
internetautomar's Avatar
mod or sell?
easiest way:
put car on lift
put jack under tank
undo gas tank straps
place 5 gallon bucket under filler neck hose.
lower gas tank down slowly
tilt tank to empty gas into bucket
get second bucket if necessary.
Old Nov 4, 2007 | 10:33 AM
Deridex's Avatar
Alright, cool. I was talking about my parts car, which is going to a junkyard pretty soon here. I stripped it of almost everything of value except the engine. It still has 3 or 4 gallons left in the tank, so I think why waste it?
Old Nov 4, 2007 | 01:52 PM
sanford7575's Avatar
Car smells like fuel; please help!!!
I know this is off topic a little bit, but I can't post new threads.
My '92SE smells of fuel big time! I just had the fuel pump replaced, and ever since the inside of the cabin reeks!
Any suggestions?
Old Nov 4, 2007 | 02:17 PM
mod or sell?
then you either have a loose line at the tank, or more than likely you need to do the fuel lines under the intake
Old Nov 4, 2007 | 04:55 PM
Any suggestions?
The gasket on the fuel tank cover may be a problem, or you may not have put the fuel lines back on fully.
Old Nov 5, 2007 | 04:24 PM
helps
or whoever replaced your fuel pump got it all over beneath the back seats.
Old Nov 30, 2007 | 09:02 AM
warbucks's Avatar
Please help
I just had my mechanic put a new fuel pump in, this fixed the solution to the car not starting, NOW there is a loud whining noise coming from the gas tank, he says its because i need a new fuel filter, can someone give me better opinion, or is my mechanics suggestion correct?
Old Nov 30, 2007 | 11:19 AM
mod or sell?
there should be some whining coming from the pump, however if it is loud then the pump is probably not the best one for the job
Old Nov 30, 2007 | 01:47 PM
92 Max's Avatar
If you reuse the fuel make sure you separate out the water that's probably in the bottom of the tank below the pickup.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
