Oil Leak
Old Nov 20, 2007 | 12:56 PM
gapboi210's Avatar
Oil Leak
I have an oil leak and after a quick glance, it look slike it is dripping off the transmission housing. I am thinking rear main seal. I looked and the valve covers appear to be dry. Sounds like this is gonna be difficult.
Old Nov 20, 2007 | 01:01 PM
helps
wipe it up and see where it comes from, rear main seal isnt to difficult.
Old Nov 20, 2007 | 01:12 PM
internetautomar's Avatar
mod or sell?
I guess you don't consider removing engine or trans too difficult
Old Nov 20, 2007 | 01:20 PM
helps
not after i did it 6 times in 1 week, i can replace a clutch on my vg in about 30-45 minutes now.
Old Nov 20, 2007 | 02:23 PM
mikekantor's Avatar
Try changing the oil pan gasket first, might be coming from there. I changed my rear main while the engine was out and that specific part of the repair had me swearing the most.
Old Nov 20, 2007 | 02:48 PM
gapboi210's Avatar
I haven't really looked yet. How hard is the oil pan gasket? I have a new engine gasket set. I wonder if it included a oil pan gasket.
Old Nov 20, 2007 | 02:55 PM
Maxteca's Avatar
You should try and do a pan gasket and rear main on a ford e-150 van.
Old Nov 20, 2007 | 02:56 PM
mikekantor's Avatar
I have a spare VG pan gasket for sale
You have to support the engine, remove the cross member, and then remove the pan.
Old Nov 20, 2007 | 02:57 PM
mikekantor's Avatar
First I'd have to try to buy domestic
Old Nov 20, 2007 | 11:13 PM
gapboi210's Avatar
pan gasket on a cadillac. exhaust has to be cut off and welded back. the
Old Nov 21, 2007 | 01:04 PM
Chris Gregg's Avatar
Get Off My Lawn
I have an extra rear main if you like.
Old Nov 22, 2007 | 10:40 PM
ColombianMax's Avatar
We did and that was FUN! had to jack the engine up to try and get the damn pan out of the crossmember frame thingy since it was on both freakin sides
Hey Ben, the oil pan is pretty time consuming, took me about 2-3 hours at work... gotta support the engine/trans, remove crossmember, y pipe can hang down, engine/trans coverplates and some other small things. It'll take you a good time doing it in a garage on your back. Its not hard nor expensive just time consuming.
If you DO do it, be sure to not start the car right away like i did I was so excited that I finished and could go home that I forgot you had to build pressure for like 30 seconds or something.
Old Nov 23, 2007 | 08:28 AM
mikekantor's Avatar
And remove the dipstick before installing the pan!
Old Nov 23, 2007 | 07:06 PM
YES, I didnt do that and I thought I farked everything up when I head a loud clicking clacking
Old Nov 25, 2007 | 09:58 AM
gapboi210's Avatar
well whatever is leaking is superslow. I stuck a piece of cardboard underneath and when I pulled it out, it was dry. Turns out looks like the puddles are coolant from my 4Runner.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
