Alternator diode pack(where to purchase?)
Old Dec 6, 2007 | 03:59 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by sonicii
I have had one of the diodes go short in my alternator, surprisingly it still seemed to be working ok (14V on the battery under load at about 2k RPM), but it would struggle to maintain charge at idle.
The symptom was a bad whining noise which varied with engine RPM, sounded exactly like a bad/dry bearing, it was very noticeable, even inside the car. I removed the alternator expecting to replace bearings, but found they were ok. I then went searching and found the shorted diode. I replaced the diode pack and fixed the noise. It now also maintains 13.8V at idle with accessories on.
Where did you purchase the diode pack at?
I have that exact same noise(kinda like a scratching noise) but so far no charging issues yet.
Old Dec 13, 2007 | 07:18 AM
Greeny's Avatar
¯\(°_o)/¯
Can this be purchased aftermarket,or from the dealer?
Old Dec 13, 2007 | 09:26 AM
disgruntled's Avatar
^^^^^From searching, I found that the diode packs are mostly purchased at dealers or rebuilders.
I also found this link to rebuild an alternator, but it did not refer to any diode packs, only a voltage regulator.
http://www.rangerovers.net/repairdet...haltrepair.htm
Hope that helps
Edit: Also found this
http://store.summitracing.com/partde...5&autoview=sku
it is made for a gm, but since some gm uses bosch type alternator also, it might fit, just don't know
Old Dec 13, 2007 | 09:36 AM
Gunther's Avatar
I don't think greenies gonna like the idea that he didn't search well enough
me thinks he will ask 'where are these links you speak of?'
Old Dec 13, 2007 | 09:44 AM
lol, yah, just notice the search part too, should have bold it for him too. Unless someone ninja edit me, the links will be as posted.
Old Dec 13, 2007 | 09:46 AM
Greeny's Avatar
¯\(°_o)/¯
Hope that helps
Thanks for the links,I guess i will just stop by my local dealership and ask if they can get only the diode pack
I wanted input from members that may have been through this,i didn't find anything revelant in search here..(i.e. hoping sonicii would see this and tell me.)
Old Dec 13, 2007 | 09:54 AM
Also helpful will be this:
Lester number 13477
This place seems to have a lot of rebuild kits, as long as it fits the Lester Number
http://www.alternatorparts.com/Extre...144%20type.htm
Old Dec 13, 2007 | 10:00 AM
Found the site that sells diode trio packs (diode packs)
http://transpo-usa.com/catalog.html
This is where I got that link from
http://www.toyotanation.com/forum/sh...270&forumid=10
The guy that posted the link rebuilds alternator for a living, so maybe you can ask him on where to get the various components.
Old Dec 13, 2007 | 12:50 PM
LvR's Avatar
LvR
Must say I am surprised that a shorted diode on the rectifier (and as a result the stator) managed to last long enough to cause irritation - I would have expected the magic blue smoke to have come out of either like pronto.
Guess the shorted diode caused large spiky currents to flow and inadequate potting varnish on the particular phase's winding may have caused magnetic interaction that set up an audible vibration.
Here in South Africa we can get diode plates for Bosh and Lucas alternators at most car spares shops.
Old Dec 13, 2007 | 12:59 PM
Greeny's Avatar
¯\(°_o)/¯
well lawrence,it is definitely an alty issue of sorts,i have verified by removing the belt(noise disappears),also the scraping noise gets louder(more than doubles) when i turn on the headlights..
But like is said prior,their is no charging issues atm..
Old Dec 13, 2007 | 01:16 PM
internetautomar's Avatar
mod or sell?
1993 NISSAN/DATSUN MAXIMA SE 3.0L Fuel Injected V6 Vin:VE30DE
Manufacturer Part Number Description Core Charge Price Details
ALTERNATOR/GENERATOR
AMPERE AUTOMOTIVE 21495 ALTERNATOR
Note: w/dohc eng; amps: 95; hitachi 50.00 376.62
ACDELCO US 321-1380 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
Note: 5s pulley; int reg; int fan; dual overhead cam; sfi; hitachi unit; (opt unit); 95 amps 150.00 343.75
ACDELCO US 321-1163 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
Note: 4s pulley; int reg; int fan; single overhead cam; sfi; hitachi unit; 90 amps 65.00 152.76
ACDELCO US 334-1172 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
Note: hitachi if (95 amps); 95 amp 45.00 343.76
AMG 13-8505 ALTERNATOR-NEW
Note: amp=90; grooves=4 0.00 *
AUTOMOTIVE IMPORTING MFG. 13477N NEW ALTERNATOR
Note: w/dohc eng 0.00 *
AUTOMOTIVE IMPORTING MFG. 13477 REMAN ALTERNATOR
Note: w/dohc eng 88.89 295.92
AUTOTECH ENGINEERING 13477 REMAN ALTERNATOR
Note: dohc 60.30 299.24
BECK/ARNLEY 186-0630 ALTERNATOR, REMANUFACTURED
Note: hitachi system, serpentine 5 groove, 95 amperes 70.00 300.55
BBB INDUSTRIES, INC. 13477 REMAN ALTERNATOR
Note: dohc; amps: 95 60.00 333.24
BOSCH AL2356X ALTERNATOR
Note: reman; dohc 123.00 306.75
CHAMPION PREM REMAN ALTS/START 14476 REMAN ALTERNATOR
Note: w/dohc 0.00 *
DNS ARMATURES A13477 REMAN ALTERNATOR
Note: int 95; lr195-701; std 0.00 *
DNS ARMATURES A14661 REMAN ALTERNATOR
Note: int 90; lr190-704; std 0.00 *
ACDELCO BASE 321-1380 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
ACDELCO BASE 321-1163 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
ACDELCO BASE 334-1172 ALL MAKES-GENERATOR - ALL MAKES (REMAN)
DIXIE ELECTRIC A-8375 REMAN ALTENATOR
Note: w/dohc; 12v; amp: 95; design: ir/if; pulley: 5s; clock: 4:30 70.00 *
EVANS REBUILT PARTS 13477 ALTERNATOR
Note: w/dohc eng; amps: 95; hitachi 0.00 *
EXCEL 10214 ALTERNATOR
Note: all w/dohc (hitachi)(95 amps) 75.00 353.90
FAE 4690 ALTERNATOR
Note: w/dohc eng; amps: 95; int reg; hitachi 0.00 *
FEDERATED ALTS/STARTERS A2889 REMAN ALTERNATOR
Note: dohc; amps: 95 0.00 *
GENCO AUTO ELECTRIC 13477 ALTERNATOR
Note: dohc; amps: 95 40.00 330.00
GENEX 13477 ALTERNATOR
HMC 13477 REMAN ALTERNATOR
HOPPER MANUFACTURING 13477 ALTERNATOR
Note: w/dohc engine; amps: 95; internal regulator; hitachi; 12v; clock-wise rotation 0.00 *
J & I AUTOMOTIVE 13477 ALTERNATOR
Note: w/dohc engine; amps: 95; internal regulator; hitachi 0.00 *
LTD PARTS 13477 ALTERNATOR-REMAN
Note: 1 per veh; w/dohc engine; amps: 95; internal regulator; hitachi; 12v; clock-wise rotation; 0.00 *
LUCAS A8240 ALTERNATOR
Note: w/dohc eng 60.00 433.21
LUCAS 13477 PLATINUM ALTERNATOR
Note: dohc eng; amps: 95; hitachi 0.00 *
LUCAS A8240 LUCAS ALTERNATOR
Note: dohc eng; amps: 95; hitachi 60.00 433.21
MACHINERY COMPONENTS INC. N13477 NEW ALTERNATOR
MPA 13477 REMAN ALTERNATOR
Note: dohc eng 0.00 *
METRON ELECTRICAL REBUILDERS, 13477 REMAN ALTERNATOR
Note: w/dohc eng; amps: 95; hitachi 40.00 243.80
MAXPOWER REBUILDERS 13477 REMAN ALTERNATOR
Note: w/dohc eng, amps: 95; hitachi 0.00 *
NASTRA AUTOMOTIVE IND., INC. A1889 REMAN ALTERNATOR
Note: dohc; amps: 95 75.00 292.10
DENSO 210-3135 ALTERNATOR
Note: dohc 34.00 316.91
NSA ALT-3203 ALTERNATOR
ORANGE COUNTY ALTERNATOR 13477 PLATINUM ALTERNATOR
Note: dohc eng; amps: 95; hitachi 60.00 399.89
ORANGE COUNTY ALTERNATOR A8240 LUCAS ALTERNATOR
Note: dohc eng; amps: 95; hitachi 60.00 367.13
ORIG EQUIP PLUS AL-889 PREMIUM ALTERNATOR
PACIFIC ALTERNATOR & STARTER 13477 REMAN. ALTERNATOR
Note: w/dohc engine; amps: 95; internal regulator; hitachi; 12v; clock-wise rotation 75.00 297.50
PRIDEMARK 14476 REMAN ALTERNATOR
Note: w/dohc 90.00 332.82
PROAMP 13477 REMAN ALTERNATOR
POWERITE AUTOMOTIVE INC. 13477 ALTERNATOR
PRO PLUS AL-889 ALTERNATOR
PRECISION PARTS REMAN DAA317 ALTERNATOR-REMAN
Note: 1 per veh; 90 amp; 0.00 *
PRECISION PARTS REMAN DAA319 ALTERNATOR-REMAN
Note: 1 per veh; 95 amp; to 1/94; 0.00 *
CARQUEST ELECTRICAL/BBB 13477A REMAN ALTERNATOR
QUALITY REBUILDERS 13100 ALTERNATOR
Note: dohc; amps: 95 70.00 292.00
RAYLOC 13-8505 ALTERNATOR
Note: amp=90, grooves=4 0.00 *
RAYLOC 1N-8505 ALTERNATOR
RELIANCE AUTOMOTIVE 41661 PREMIUM ALTERNATOR
Note: hitachi, 90 amp., sohc 35.00 204.60
RELIANCE AUTOMOTIVE 41662 PREMIUM ALTERNATOR
Note: hitachi, 95 amp., dohc 60.00 319.20
REMY 14476 REMAN ALTERNATOR
Note: w/dohc 0.00 *
SUN COAST AUTOMOTIVE PRODUCTS 13477 REMAN ALTERNATOR
Note: dohc; amps: 95 80.00 273.70
TRUST 13477 ALTERNATOR-REMAN
Note: 95a 0.00 *
USA INDUSTRIES ELECTRICAL PROD A2889 REMAN ALTERNATOR
Note: dohc; amps: 95 67.00 *
UNIPOINT ALT-3203 ALTERNATOR
VIP BATTERIES 13477 ALTERNATOR-REMAN
Note: 95a 0.00 *
VIP BATTERIES 13477 ALTERNATOR OPT-REMAN
Note: 95a 0.00 *
VISTEON ALTERNATORS/STARTERS 13477 REMAN ALTERNATOR
WILSON AUTO ELECTRIC LTD. 90-25-1026 ALTERNATOR
Note: w/sohc; volt- 12, 90amp 60.00 *
WILSON AUTO ELECTRIC LTD. 90-25-1072 ALTERNATOR
Note: w/dohc; volt- 12, 95amp 60.00 *
WORLDWIDE 14476 REMAN ALTERNATOR
ALTERNATOR BEARING
AUTOPRIDE PRIVATE LABELS 6303-2RSJ ALTERNATOR DRIVE END BEARING
Note: front 0.00 *
AUTOPRIDE PRIVATE LABELS C6303-2RSJ ALTERNATOR DRIVE END BEARING
Note: front 0.00 *
AUTOSTAR PRIVATE LABELS 201-CC BALL BEARING
Note: hitachi 90 amp 0.00 5.84
AUTOSTAR PRIVATE LABELS 303-CC BALL BEARING
Note: hitachi 90 amp 0.00 10.08
NATIONAL SEAL/BEARING/HUB ASSY 201-CC BALL BEARING
Note: hitachi 90 amp 0.00 27.57
NATIONAL SEAL/BEARING/HUB ASSY 303-CC BALL BEARING
Note: hitachi 90 amp 0.00 51.10
PARTS PLUS BEARINGS & SEALS P303CC BALL BEARING
Note: mitsubishi 110 amp 0.00 *
Note: hitachi 70 amp 0.00 *
Note: hitachi 80 amp 0.00 *
Note: hitachi 90 amp 0.00 *
Note: hitachi 70, 80, 90 amp 0.00 *
PRECISION AUTOMOTIVE INDUSTRIE 201-CC ALTERNATOR REAR END BEARING
Note: hitachi 90 amp. fwd 0.00 *
PRECISION AUTOMOTIVE INDUSTRIE 302-CC ALTERNATOR DRIVE END BEARING
Note: mitsubishi 90 amp., rwd 0.00 *
Note: mitsubishi fwd 0.00 *
PRECISION AUTOMOTIVE INDUSTRIE 303-CC ALTERNATOR DRIVE END BEARING
Note: hitachi 70,80,90 amp. 0.00 *
PRONTO PT201-CC ALTERNATOR BEARING
Note: rr. end; hit.; 90 amp. 0.00 *
PRONTO PT302-CC ALTERNATOR BEARING
Note: d.e.; mit.; 70 amp. 0.00 *
POWERTRAIN COMPONENTS (PTC) PT201-CC ALTERNATOR BEARING
POWERTRAIN COMPONENTS (PTC) PT302-CC ALTERNATOR BEARING
SKF (CHICAGO RAWHIDE) 6303-2RSJ ALTERNATOR DRIVE END BEARING
Note: front 0.00 49.95
SKF (CHICAGO RAWHIDE) C6303-2RSJ ALTERNATOR DRIVE END BEARING
Note: front 0.00 *
TIMKEN 303CC BALL BEARING
Note: mitsubishi 110 amp 0.00 60.43
Note: hitachi 70 amp 0.00 60.43
Note: hitachi 80 amp 0.00 60.43
Note: hitachi 90 amp 0.00 60.43
Note: hitachi 70, 80, 90 amp 0.00 60.43
ALTERNATOR BRUSH SET
BORG WARNER X540 ALTERNATOR BRUSH SET 0.00 9.39
Note: w/alt #lr190-711, hitachi 0.00 9.39
GP SORENSON 25-5016 ALTERNATOR BRUSH SET 0.00 9.66
Note: w/alt #lr190-711, hitachi 0.00 9.66
NIEHOFF WA547 ALTERNATOR BRUSH SET 0.00 9.39
STANDARD MOTOR PRODUCTS JX-108 ALTERNATOR BRUSH SET 0.00 9.66
PULLEY
AUTOSTAR PRIVATE LABELS 45006 IDLER/TENSIONER PULLEY
Note: ac mounting 0.00 *
COOLING DEPOT 11145006 IDLER/TENSIONER PULLEY
FACTORY AIR 45006 IDLER/TENSIONER PULLEY
FOUR SEASONS 45006 IDLER/TENSIONER PULLEY
Note: ac mounting 0.00 27.33
GATES 36115 BELT DRIVE PULLEY
Note: wp & ps; w/sohc eng 0.00 60.00
PARTS MASTER 45006 IDLER/TENSIONER PULLEY
CARQUEST/GATES 36115 BELT DRIVE PULLEY
Note: wp & ps; w/sohc eng 0.00 29.97
TORQFLO BY COMPRESSORWORKS, IN 835006 IDLER PULLEY 0.00 *
VOLTAGE REGULATOR
ACDELCO US C641 VOLTAGE REGULATOR 0.00 216.64
ACDELCO US E634C VOLTAGE REGULATOR
Note: alt 23100-96e01 0.00 *
AIRTEX ENG. MGMT. SYSTEMS 1V1228 VOLTAGE REGULATOR
Note: dohc 0.00 *
CARQUEST VR-537 ALTERNATOR - CHARGING SYSTEM PARTS-VOLTAGE REGULATOR
Note: ; alt. 23100-96e01 0.00 *
ACDELCO BASE C641 VOLTAGE REGULATOR 0.00 216.64
ACDELCO BASE E634C VOLTAGE REGULATOR
GP SORENSON 26-5143 VOLTAGE REGULATOR
Note: alt. 23100-96e01 0.00 215.56
KEMPARTS KVR616 VOLTAGE REGULATOR
Note: w/alt# 23100-96e01 0.00 372.05
STANDARD MOTOR PRODUCTS VR-537 VOLTAGE REGULATOR
WELLS VR938 VOLTAGE REGULATOR
Note: dohc 0.00 382.07
WILSON AUTO ELECTRIC LTD. 62-25-16064 VOLTAGE REGULATOR
Note: w/sohc; volt- 12, 90amp 0.00 *
WILSON AUTO ELECTRIC LTD. 62-25-16094 VOLTAGE REGULATOR
Old Dec 13, 2007 | 01:23 PM
Greeny's Avatar
¯\(°_o)/¯
thanks?
Old Dec 13, 2007 | 01:24 PM
mod or sell?
your welcome
formatting gets lost on the forums
Old Dec 13, 2007 | 02:43 PM
sonicii's Avatar
I live in Australia and I purchased them through an aftermarket auto electrical chain called 'ashdown'. But I don't know where you woudld get them in the US.
Old Dec 13, 2007 | 02:50 PM
Greeny's Avatar
¯\(°_o)/¯
Ahh..ic
thanks
Old Dec 13, 2007 | 04:35 PM
Gunther's Avatar
my sarcasm never seems to penetrate these forums
Old Dec 14, 2007 | 08:17 AM
1992maximase30's Avatar
damn! $350 for a ve alternator?!
why's the vg cheaper?!
Old Dec 14, 2007 | 08:24 AM
Greeny's Avatar
¯\(°_o)/¯
They are not that expensive typically..
http://forums.maxima.org/showthread.php?t=537624
Old Dec 14, 2007 | 08:55 AM
mod or sell?
those are LIST prices.
Old Dec 14, 2007 | 08:42 PM
oh okay.
i was on autozone.com and seen the price my mouth dropped.
my legend alternator was $100.
but then i read the thread where the ve was "rare" compared to the vg.
i think my alternator was making that noise too.
i adjusted the belt.
and i even tested the voltage load too.
at low idle (gotta adjust it) the alternator was kicking out 14volts with the lights on, defog, a/c on and full blast.
with everything off but fans it was 14.38volts.
Old Dec 16, 2007 | 03:12 AM
sonicii's Avatar
oh okay.
14.4V seems a bit high. Charging a 12V lead acid battery above 14.2V for an extended time may cause damage.
Old Dec 24, 2007 | 08:41 PM
well it probably went down now becuase john cleaned my cables better than i did.
could've been pumping out when they had to much corrosion.
Old Dec 24, 2007 | 09:19 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i have a strange sound happening (sounds like a bearing.. like sonicii's did) so could i unbelt my alternator or electrically disconnect my alternator as a way of testing this?
Old Dec 25, 2007 | 07:43 AM
Greeny's Avatar
¯\(°_o)/¯
Remove each accessory belt one at a time,start car,until the noise goes away.
Old Dec 25, 2007 | 08:06 AM
Pearl93VE's Avatar
I can has?
You good on power steering fluid? I thought I had a bad bearing because of a weird noise like that and my pump must have just been low on oil. Filled up my Power steering (Which apparently has a leak) And it went away.
Old Dec 25, 2007 | 08:49 PM
car can be driven 50 feet w/o wpump going? if car is not fully warm? i can wrench the wheel around as far as the ps pump being unattached but is it safe to run without the wpump going for a short time?
Old Dec 25, 2007 | 09:03 PM
Alex_V
Yea, a quick jaunt around the block should be fine.
~Alex
Old Dec 25, 2007 | 09:13 PM
~Alex
JAUNT. i like that word. don't see it much.
i'm just doing a short drive up to the neck of the cul-se-sac going maybe 15-20mph in 1st. 1st is the only time road/wind noise is quiet enough to really hear the engine at those RPMs while in gear. I will survey noise in neutral as well.
after i do a run with ac belt and alty belt off if it still makes noise i think i'll undo the alty wiring to rule out the diode/electronics of the alternator/voltage regulator etc. if that doesn't fix it i'll go ahead and take off the ps/wpump belt so the coolant will only be stationary for one run.
unless i start with all of them off, and then add belts back. that may be a better idea.
Old Dec 25, 2007 | 11:03 PM
Pearl93VE's Avatar
I can has?
err... Still sounds like it could be power steering related, I'd check it at least before continuing. Can't you have someone turn the wheel while you listen by the passenger wheel? It's not the classic "errr" noise the power steering pump usually makes, it's more of a buzzing/zzzing that sounds like it could be a bearing. I don't know, might be worth checking...
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
