Automatic trans preventative maintinance.
Old Feb 6, 2008 | 07:15 PM
  #81
Big_E-Dog's Avatar
2nd Gen Boostinator
not to sound dumb or nothing but is the overdrive on?? and is there enough fluid in there and if there is enough fluid is it burnt, because if it is then youll just have to change it, im doing that now myself in my 2nd gen then when i finish ima get the car painted yay!
Old Feb 6, 2008 | 07:47 PM
  #82
Mysticcal's Avatar
OD was on but i've also used OD off as well to the same effect, OD seems to give more power since I only have the 2 gears available to me to drive (prolly gonna burn up this tranny that way if I dont change it soon), the tranny fluid looks good and it doesnt smell burnt or discolored...
if this was directed at me (hope it was and I wasn't just responding dumbly)
Also, anyone know any other FWD Nissan Transmissions that would also fit on a VE30DE? or is it just the one?
Old Feb 6, 2008 | 08:06 PM
  #83
BenStoked's Avatar
Jesus was a Zombie.
the other 3rd gen auto bolts to the engine, however the starter is in hte wrong place(or something like that.)
Old Feb 6, 2008 | 08:08 PM
  #84
ColombianMax's Avatar
down shifting to 1st will always cause a major slow down and if done going fast enough can hurt your trans...
Old Feb 6, 2008 | 08:22 PM
  #85
Mysticcal's Avatar
I was just trying to confirm it was 2nd gear the tranny wasn't upshifting from and not 1st...
I'm gonna call my regular mechanic tomorrow and see if he rebuilds transmissions. for some reason I thought that if I went to an AAMCO like situation that it would be better then my typical mechanic situation. if he can't rebuild it, i'll start looking for transmissions in the area.
EDIT: Just found this http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWDVW
anyone think it's legit?
Old Feb 6, 2008 | 08:43 PM
  #86
Greeny's Avatar
¯\(°_o)/¯
Wrong transmission dude..
Old Feb 6, 2008 | 08:48 PM
  #87
Mysticcal's Avatar
just my luck.
Old Feb 6, 2008 | 09:25 PM
  #88
How the hell you find that? doesnt say maxima not even ONCE in that whole page
Old Feb 6, 2008 | 09:36 PM
  #89
Mysticcal's Avatar
eh, looking for nissan transmissions in general, found out that the same transmissions from similiar year engine type Quests and i30s are the same... so we'll see.
Old Feb 7, 2008 | 06:45 AM
  #90
BenStoked's Avatar
Jesus was a Zombie.
i30, no its a vq engine, so it wont bolt right, quest, vg, so mebe.
(VE5 SWAP FTW!!!!!)
Old Feb 7, 2008 | 07:37 AM
  #91
internetautomar's Avatar
mod or sell?
then you need a trans.
Old Feb 7, 2008 | 07:52 AM
  #92
mod or sell?
eh, looking for Nissan transmissions in general, found out that the same transmissions from similar year engine type Quests and i30s are the same... so we'll see.
OK a little clarification
the VE motor in the 3rd gen took a transmission called an RE4F04V
the VG motor in the 3rd gen took a transmission called an RE4F02A
the VQ in the max from 95-01 uses a transmission called an RE4F04A
the VG in the quest uses a transmission called a RE4F04A
the A suffix means an open differential versus the V suffix which indicates the presence of a VLSD.
While the trans from a quest will bolt up to a VG engine I am not aware of anyone who has used it or even tried to. it may or may not have the mount in the same locations as the 3rd gen.
we do know that the VE A/T can not be used on the VG because of starter location issues.
Old Feb 7, 2008 | 09:17 AM
  #93
Mysticcal's Avatar
much appreciated helps me out a lot in the longrun.
Old Feb 7, 2008 | 01:22 PM
  #94
mod or sell?
Originally Posted by benstoked
please correct me if I am wrong, but even though the numbers are the same, they do not share the same case, just internals. the bolt patterns are not the same for vg and vq.
you need the WHOLE line.
the QUEST got the RE4F04A with it's VG
the MAXIMA got the RE4F02A when it was powered by the VG
transmissions ID #s are realted to the # of gears, whether it is FWD or RWD, Torque Capacity, and whether it had a limited slip differential or not.
Old Feb 7, 2008 | 01:28 PM
  #95
BenStoked's Avatar
Jesus was a Zombie.
mkay, if i had seen that, i would not have asked
Old Feb 7, 2008 | 01:49 PM
  #96
mod or sell?
I added it to the post
Old Oct 17, 2008 | 11:48 AM
  #97
lemans3427's Avatar
EZ Lube charges $99 for a tranny flush. Should I pay this or do it myself?
Old Oct 17, 2008 | 12:04 PM
  #98
Greeny's Avatar
¯\(°_o)/¯
Do not have your transmission flushed...It will loosen up all the gunk and stuff that has attached itself to the casing over the years, then not all this gunk is not removed by the flush.so the gunk is now floating around in your transmission, where does it go? yep you guessed it right to your valve body, now you have a clogged valve body and a slipping transmission.
Just go pick up about 9 quarts of this...
Drain out the old fluid, only about 3 quarts will come out at a time, the rest is still in the torque converter and other lines/valves in the tranny. refill it with the correct amount of fluid, then go for good stop-n-go drive, repeat the drain/refill/drive about three times and you will have most of the old fluid replaced.
Old Oct 17, 2008 | 12:15 PM
  #99
lemans3427's Avatar
So after each round of stop-n-go's 3 more gallons of the old fluid should drain out?
Old Oct 17, 2008 | 12:21 PM
  #100
Greeny's Avatar
¯\(°_o)/¯
Well, it will be the old fluid mixed with the newer fluid, but after 3 or 4 of these rounds you will have mostly new fluid..
And thats 3 QUARTS, not gallons.
Old Oct 17, 2008 | 12:30 PM
  #101
augiedog964's Avatar
Check Wiking's cardomain. It has instructions on how to do it. Search around for it. Site says it is deleted, but it is a lie, just use the set of numbers that works, and not the ones that don't. Sorry I don't have the link. If you are in the south NJ area, I have some Nissanmatic D if you want it.
Old Oct 17, 2008 | 12:38 PM
  #102
Greeny's Avatar
¯\(°_o)/¯
http://www.cardomain.com/ride/748507/24
Old Oct 18, 2008 | 12:41 AM
  #103
Wiking's Avatar
That site is crap, dont go there
Anyways, for maximum swap I now use the 30$ 12V oilpump. Cleanest way to suck all old out from bottom reservoir via stick tube, then fill in new ... (Best way is to open first time the drain plug)
One Swap Process:
1. old out / new in ...
2. idling for fifteen seconds - will suck about 3 quarts = all new oil into the system.
3. Goto 1. = repeated, total is 3times.
While idling, do play through all gears so that all the various gear channels have a chance to get new oil flow through.
Result: Most oil has been swapped, while no danger to get air bubbles. Imperfect: used oil is being pumped onto new and gets mixed... in the reservoir
Remember later to check level when hot.
Old Oct 18, 2008 | 05:41 PM
  #104
mod or sell?
says the man who created it.
Old Oct 19, 2008 | 12:12 AM
  #105
Wiking's Avatar
says the man who ...
oops
edit oopsII: Now the CDomain geniuses have found out about fonts, sizes, color ... vow. Hope this time their whims last overnight and the kids wont change site settings and ruin all script addresses & page layout commands - as they have been soing 'every month' since 05....
Again, during editing the site gave umpeenth time the [SITE on SERVICE] -message, losing all painstakingly edited forms
Old Oct 26, 2008 | 06:08 AM
  #106
Wiking's Avatar
oops...Again, during editing the site gave umpeenth time the [SITE on SERVICE] -message, losing all painstakingly edited forms
CarDomain has now introduced html -format in secrecy. Only if this would last (never has before), then the page(s) could stay readable.
Check out. http://www.cardomain.com/ride/748507/24
Old Oct 26, 2008 | 07:14 AM
  #107
mod or sell?
Write them all up in standard HTML as full pages and I'll email you an ftp login to host them at.
Old Oct 26, 2008 | 08:26 AM
  #108
Wiking's Avatar
Can be done; the mess has to be organized for a purpose.
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
