Rpm signal wire on Ecu?
Old Jan 11, 2008 | 07:56 PM
akurtzer57's Avatar
I have installed my SAFCII up to the rpm signal wire. The only way I know to find it is in a FSM which I can't order or the closet one to look at is 50 miles away at a dealer. Is what im needing to know is which pinout on ecu is the rpm signal wire? I have a 1991 maxima 5spd VG30E...any help?
Old Jan 11, 2008 | 08:12 PM
Alex_V
send a pm alex...
thanks
MGM94
Old Jan 12, 2008 | 03:58 PM
internetautomar's Avatar
mod or sell?
if all you need is a tach signal, you can tap into one of the injector wires and that will give you your signal as well.
Old Jan 12, 2008 | 04:23 PM
BenStoked's Avatar
Jesus was a Zombie.
pm sent when i noticed what it was, alex.
Old Jan 12, 2008 | 06:24 PM
Alex_V
Oh ok noted...
~Alex
Old Jan 12, 2008 | 06:31 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
LG/B (light green w/ black strip) wire that you can find from the ECU (pin #7), or from your cluster. it's on the black (middle) connector if you take it from the cluster.
Old Jan 12, 2008 | 06:46 PM
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by Alex_V
Oh ok noted...
~Alex
did the same thing a while back.
copy write ftl...
BrandonCause
Sep 14, 2015 10:41 PM
Maxxx10
Sep 13, 2015 03:16 PM
ballerchris510
Sep 10, 2015 09:35 PM
