Buy complete strut spring pkg?
Old Jan 17, 2008 | 07:48 PM
gapboi210's Avatar
Is there anywhere that sells the strut, spring and mount all together new? I would rather do this. I heard that O'Reilly's used to ro still does for some cars.
Old Jan 17, 2008 | 07:51 PM
Greeny's Avatar
¯\(°_o)/¯
http://shox.com/
Old Jan 17, 2008 | 09:19 PM
gapboi210's Avatar
looks like only sets that will lower the car.
Old Jan 17, 2008 | 11:18 PM
ColombianMax's Avatar
I remember when I worked at the parts store they had complete strut assembly kits from Monroe which were what you've described just ready to bolt on. I highly doubt they have that for the max for some reason. They never make jack for our cars but either way, why you so lazy you crazy boi I mean gapboy
Old Jan 18, 2008 | 02:38 AM
Hectic's Avatar
boygap: Just install some good cartridges, it ain't that hard or as percise as you are thinking it is.
Old Jan 18, 2008 | 10:32 AM
gapboi210's Avatar
I have done struts on it before. It needs new struts and mounts so I figured might as well put new springs and get it in a kit where i don't have to compress the spring just bolt the whole thing on and it take it to get aligned.
Old Jan 19, 2008 | 01:41 AM
maximagician's Avatar
i still dont see how our cars can be "unaligned"after changing a strut or ball joint , control arm, or sway bar up front i can see it for tie rods since toe in\out seems to be the only adjustment. there is a little wiggle where the 2
lower strut bolts are and maybe a little where the 3 strut tower bolts arebut i just dont think tighting them would hold em in place for very long they will settle however the wieght of the car tells them to(3 strut tower nuts are only 29-40 ft lbs and the lower strut bolts are
a little buffer at 116-123 f s m pg.FA-4
think potholes and curbs and hard cornering etc.
now look at f s m pg.FA-7 it states"camber,caster and kingpin inclination
are preset at the factory and cannot be adjusted"(now they can be measured to look for bent or worn parts though)
i got a lifetime alignment deal on my 91 (on sale ) a few years agoand havent had it done agian because the used tires i buy "are so bald "or my popped dust boots on the inner tierods or whatever so i dont want
ask for one till i get better used or new tires or else"they cant legaly let me drive away after they turn me down "and i ll have to buy new tires on the spot
popped dustboots
Old Jan 19, 2008 | 01:43 AM
oh believe me, a strut change WILL un align it. I've had to get a share amount of alignments
Old Jan 20, 2008 | 01:07 PM
hey ,i didnt write the FACTORY SERVICE MANUAL i just believe IT
see pg FA - 7 F.S.M. (qoute)" 1. camber ,2. caster and 3. kingpin inclination ...are preset at the factory and cannot be adjusted" thats 3 out of 4 adjustments that cant be done
leaving toe in\out
see pg RA- 5 F.S.M ..qoute"camber is preset and cannot be adjusted" caster and kingpin inclination are not applicable
leaving only toe in\out ...once agian only one available
adjustment
seems to me our cars are easy to align(toe is the only adjustment)(100 bucks to set toe?)the same to do
alot more on other cars?
thats like getting charged for a cap , rotor and wires
on a VE tuneup
Old Jan 20, 2008 | 10:17 PM
gapboi210's Avatar
You will need an alignment. There is room for the whole assemble to me angled based off those 2 bolts.
Old Jan 25, 2008 | 07:00 AM
VEvolution's Avatar
I miss my VE
I don't know, but my alignment was WAY off after front struts replaced. Stupid long *** SE springs
leaving toe in\out
adjustment
thats like getting charged for a cap and rotor
on a VE tuneup
Old Jan 25, 2008 | 08:46 AM
Mike90SE's Avatar
What did the springs length have to do with it? I thought it was because of the slots in the lower mounting holes that give the problem.
Old Jan 25, 2008 | 03:52 PM
BenStoked's Avatar
Jesus was a Zombie.
lower'd springs change camber?
Old Jan 25, 2008 | 08:31 PM
Mike90SE's Avatar
I may not be the sharpest tool in the shed, but where does he say lower'd springs? He actually says he changed struts. Maybe I missed something. Ima just saying.........
Old Jan 26, 2008 | 06:21 AM
VEvolution's Avatar
I miss my VE
Nothing, was just mentioning how freakishly long I found the springs to be when doing the front struts.
Old Jan 26, 2008 | 06:47 AM
Mike90SE's Avatar
I wasn't questioning you. I thought benstoked was trying to explain how springs changed the camber on your car. I have to agree with you, the pharking springs on the front are a biotch to compress enough to get the struts out.
I agree benstoked, lowered springs will change camber. If that is what you were alluding to.
Old Jan 26, 2008 | 11:32 AM
BenStoked's Avatar
Jesus was a Zombie.
LOL, I thought that he had mentioned using lowered springs, and drop springs change camber, as we know
Old Jan 27, 2008 | 02:55 AM
yes,lowering these cars will give a negative camber...
but i still dont think its adjustable without a kit
and changing a strut on these cars should'nt change toe in\out
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
