rs50a tranny wont stuck in 1st or 2nd but shifter is in neutral???
Old Jan 28, 2008 | 05:25 PM
akurtzer57's Avatar
Tranny is pretty fresh and after installed it I moved through the gears and it was all fine. I was under the hood and had a friend go to start it and all of a sudden he went to shift and the shifter pulled back to neutral but think the for is still engaged in 1st or 2nd try to move car and it is in gear! Is there any way to get it unstuck without pulling the tranny?
Old Jan 28, 2008 | 05:32 PM
Pearl93VE's Avatar
I can has?
First off... I had a really hard time comprehending your question, if there was one.
It sounds like you didn't install the shifter linkage correctly. Did you replace all bushings when you were under the car? More information about your problem would help shed some insight on your problem.
Old Jan 28, 2008 | 06:19 PM
505max94se's Avatar
Sounds like you didn't install the check ball system properly. You're probably missing the check ball pin or one or more of the check *****.
You'll have to crack the case again...
Old Jan 28, 2008 | 07:36 PM
akurtzer57's Avatar
can pull a rs50a in 45 min done it so much but thats without my turbo in the way
Old Jan 28, 2008 | 07:51 PM
505max94se's Avatar
It's possible to crack the case while the tranny is still bolted to the motor. It's faster, but it's more difficult to work on it.
Old Jan 28, 2008 | 08:19 PM
xx-Marshall-xx's Avatar
kthxbye2u
HOLY... I would not want to do that.
Check ball? You have to have the shifter in a certain place when you install the transmission?..... I am confused. I just put my tranny in... obviously I missed something. I didnt take apart any shift linkage.
Old Jan 28, 2008 | 09:00 PM
505max94se's Avatar
Why, I've done it about 5 times...
Check ball?
I don't want to explain what a check ball is or does.
You have to have the shifter in a certain place when you install the transmission CASE?..... I am confused.
LOL
If you didn't unbolt the shift linkage, you wouldn't have been able to remove the tranny.
He said that he went through all of the gears and then it got stuck in 1st or 2nd while the shifter was in the neutral position. If he didn't hold the shifter in the correct position when he put the case back together, he wouldn't have been able to shift into ANY gear...
Old Jan 29, 2008 | 07:27 AM
akurtzer57's Avatar
ive noticed when inside and putting case on best to shift it into 1st the putting case on otherwise the case will shift it into 1st by bumping something inside. but i did it right cause soon it worked fine for a while. just going to pull tranny again turbo is in the way big time.
Old Jan 29, 2008 | 05:50 PM
Matt93SE's Avatar
STFU n00b!
follow the directions in the FSM. It tells you which way to shift everything during assembly.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
