Door locks quit!
Old Feb 2, 2008 | 04:27 PM
watut's Avatar
Door locks quit!
hey guys my parents maximas power door locks just quit. My dad was changing the oil, then after the power door locks wouldn't work. you have to unlock/lock each one manually, when you push the pdl button nothing happens. I couldn't find any fuses for the system
Old Feb 2, 2008 | 05:16 PM
internetautomar's Avatar
mod or sell?
then check all the fuses.
Old Feb 2, 2008 | 06:19 PM
MaximaMark123's Avatar
I used to have to twist the key in the door lock twice to unlock all the doors. Now I just twist once to do it. And I never got my remote to work at all.
Old Feb 2, 2008 | 08:42 PM
Mysticcal's Avatar
I'd also like some info on this as I cannot seem to get my key to fully lock the driver door from the outside, seems to only lock fully from the inside, but i suppose thats a door panel issue maybe
Old Feb 2, 2008 | 08:47 PM
watut's Avatar
I checked all the fuses and it worked. I gave the door panel (by the pdl switch) a whack and it worked again hmm. Maybe there;s a loose connection
Old Feb 2, 2008 | 09:47 PM
Cliff Clavin's Avatar
Way out West
Do some searching. Your door lock timer probably is broken or has a bad solder in it.
Old Feb 3, 2008 | 02:44 AM
elusivemax93's Avatar
it is the door lock timer. its under your steering wheel to the right and it is the most commen thing to go wrong and have failing door locks. its the soldering inside the unit and ill say this for those not able to do a good soldering job dont mess with it. i would recommend either A getting a new unit from Nissan or B risk it and buy a used unit from a salvage yard.
Old Feb 7, 2008 | 01:23 PM
mthomas002's Avatar
Anyone have pic of this door lock timer unit i cant seem to find it??? My passenger door will lock but will not unlock i want to replace this unit to see if it will help.
Old Feb 7, 2008 | 10:27 PM
Mike90SE's Avatar
I just had this same problem....it is the actuator inside the passenger door. replace it and your troubles are gone.
Old Feb 8, 2008 | 12:30 AM
ColombianMax's Avatar
Another way to tell if its bad will be a loud tick/click under your steering wheel immediately after attempting to lock or unlock your doors.
I'm currently acquiring one and fixin it for another member. If anyone else is interested I can probably pick some more up and resolder all the joints and let em slide for fair prices
Old Mar 18, 2008 | 06:47 PM
0ldsch00ld0g's Avatar
Thanks same problem
I'm new to my car and that is one of the things wrong with mine. Pasenger side won't unlock. I love the keypad entry. Only had the car 3 days. Like it so far.
Old Mar 18, 2008 | 06:54 PM
ale92se's Avatar
turn the key twice and all the doors should be unlocked.
Old Mar 18, 2008 | 07:00 PM
BenStoked's Avatar
Jesus was a Zombie.
on my car all the doors except the front passenger unlock with one key turn
Old Mar 18, 2008 | 07:13 PM
augiedog964's Avatar
isn't it different for 89-91's and 92-94. my 89 unlocks and locks all doors with one turn. except the passenger side only unlocks all doors, doesn't lock them, but the manual says this is how it is supposed to work...
Old Mar 18, 2008 | 07:18 PM
shoult's Avatar
My 92 unlocks the door the key is stuck in with the first turn, then the other three doors with a second turn. I haven't tried locking them since I always use the door button.
Old Mar 19, 2008 | 12:57 AM
maximaman1313's Avatar
I've never soldered anything in my life and i was able to fix mine np. 10bucks for soldering iron from radio shack and 30minutes of labor and it was fixed. works great now and continues to work great.
don't get a new unit. I'm sure if you are too worried about ruining it if you can't solder, im sure someone you know can do it.
Old Mar 19, 2008 | 03:58 AM
Wiking's Avatar
Originally Posted by maximaman1313
...you know can do it.
Heres one writeup for the timer http://www.thewardrops.com/maxima/
Problem may or may not sit t here - resolder wont hurt if done properly = ensures that all prospects for this problem will run out from t here.
Banging the door wont affect timer, possibly door actuator /contacts...
Door lock pwr comes via Batt fusible link (grn), under the hood. Then the wiring to door locks goes through the Super Multiple Junctions =SMJ's. There is a circ breaker in the left farthest corner under dash (a short makes it...clic clic).... There it goes to door lock timer, a box under dash.
If I get it right, door keyhole switch gets juice via 10A fuse, left, second from bottom.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
