So what is the best spark plug?
Old Feb 11, 2008 | 04:20 PM
Thanatos's Avatar
The Floor Is Open .
Old Feb 11, 2008 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
The information is all in the spark plug thread you were just reading
Old Feb 11, 2008 | 04:41 PM
Thanatos's Avatar
all i found in there is a bunch of people who couldnt make their minds up. that is why i am re-opening and making a new thread.and the last post in that thread was in 10-09-2006 so i think we need to address who thinks what is better. do you agree.
Old Feb 11, 2008 | 04:50 PM
BenStoked's Avatar
Jesus was a Zombie.
use ngk.
bosch sucks.(says the concensus)
Old Feb 11, 2008 | 04:55 PM
Matt93SE's Avatar
STFU n00b!
The consensus is the same. use NGK. only use NGK. use any NGK you want, but you'll be fine as long as it says NGK on it.
Old Feb 11, 2008 | 05:05 PM
93SCMax's Avatar
98 SE
Agreed...NGK for best results.
Old Feb 11, 2008 | 05:21 PM
BenStoked's Avatar
Jesus was a Zombie.
Okay, this thread is obviously going nowhere.
to liven things up a little bit, people running NGKs put out which NGKs you run, and, if applicable, why you chose that plug.
NGK's website shows these plugs for the maxima(both vg and ve)
Standard, V-Power, G-Power, Laser Platinum, OE Laser Iridium, Iridium IX
Old Feb 11, 2008 | 05:27 PM
Thanatos's Avatar
thank you. i have always ran NGK in all my vehicles any way. i just wanted to know who thought what was the best and why.
Old Feb 11, 2008 | 05:29 PM
Thanatos's Avatar
just so you know Greeny. i wasnt trying to be an ***. just trying to gain knowledge thats uptodate .
Old Feb 11, 2008 | 05:30 PM
BenStoked's Avatar
Jesus was a Zombie.
LOL! CLARITY gets answers. OP was kinda vague, thats why there have been obvious answers.
as for me, I have bosch, but I need to replace those and the wires.
Old Feb 11, 2008 | 05:32 PM
Thanatos's Avatar
as of now i have the NGK R PFR6G in mine.
Old Feb 11, 2008 | 05:33 PM
Greeny's Avatar
¯\(°_o)/¯
I use ngk v power only..
The ve comes with ngk platinums stock,and are recommended by the manufacturer, but i have had no problems at all running v power coppers for years. you have to replace the v powers more often,but much cheaper then the laser plats($12X 6= $72) VS. V power( $3X 6=$18)
but as matt said prior..Use any plug you want..as long as it's a NGK plug..
Old Feb 11, 2008 | 05:34 PM
Greeny's Avatar
¯\(°_o)/¯
Heh...i was just messing with ya mang..It all good
Old Feb 11, 2008 | 06:14 PM
nForce's Avatar
The Computer Guy
NGK Iridium IX is the only way to go if you have the extra $$ they cost about 9 bucks a plug I have ran them on my maxima for about 2 years now and they still look clean and still has strong responses.
Old Feb 11, 2008 | 06:19 PM
JAMAICANLOVRBOY's Avatar
whatever u do, stay away from bosch...NGK is the way to go for nissan
Old Feb 11, 2008 | 08:56 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i used bosch plats for about 4 months and immediately noticed a loss in low end power. then i joined the org, and got ngk v-powers and have been satisfied. a fixed o2 sensor harness didn't hurt either (that one wire alone jumped my fuel economy up by a solid 40%, sometimes higher) but the broken studs are working against me. overall, I regret buying those stupid bosch plugs and i have returned to the stock Nissan plug wires against the Duralasts, hoping that the OEM stuff is better.
while we are on the topic of ignition......
anyone have a preferred cap/rotor combo in their VGs?
Old Feb 12, 2008 | 07:29 AM
internetautomar's Avatar
mod or sell?
yeah, converting to DIS
Old Feb 12, 2008 | 07:39 AM
mikekantor's Avatar
Apparently I am a heretic for using Bosch Platinum.
Old Feb 12, 2008 | 07:46 AM
DIS = distributorless ignition system? and we do that on a vee gee how? using the crank angle sensor, and by that i may actually mean camshaft angle sensor (the stupid thing that tells the injectors when to fire) and running it off that? also, by adjusting the timing of the distributor do you also adjust the timing of the injectors or does that sensor stay put as you are turning the distributor?
Old Feb 12, 2008 | 08:16 AM
mod or sell?
it was intended as an allusion to getting a VE
Old Feb 12, 2008 | 08:51 AM
VEvolution's Avatar
I miss my VE
why does bosch suck again? people experiencing poor idle?
Old Feb 12, 2008 | 09:08 AM
Alex_V
They just don't work as well due to their internal design. My frist max has bosch plats in it and I put in NGK v powers and it ran smoother and a little stronger. And for the VE's Ive read it contributes to coil pack failure.
~Alex
Old Feb 12, 2008 | 09:49 AM
maxitech's Avatar
NGK is the way to go...I run them in my Maxima and my Ski-Doo...I think my winter beater has AC Delco plugs tho...
Old Feb 12, 2008 | 10:02 AM
VEvolution's Avatar
I miss my VE
~Alex
i wonder if they make them better for their german applications
Old Feb 12, 2008 | 10:30 AM
mod or sell?
Fact: 75% of OE plugs are NGK
Fact: Most newer european cars no longer use Bosch plugs from the factory
Bosch has become an autozone plug to me. they are cheap and made to cheap specs so that people can feel good about putting in a platinum plug that doesn't cost $5
Old Feb 12, 2008 | 12:59 PM
BenStoked's Avatar
Jesus was a Zombie.
(blah blah blah)
...as for me, I have bosch, but I need to replace those and the wires.)
just got the v-powers installed. BIG difference in idle. haven't yet gotten to driving it, but i can tell by revving its gonna be funner to drive.
wires are on order. get those tomorrow...
(btw, bosch platinums (FTL...) came with the car.)
Old Feb 13, 2008 | 06:16 PM
Matt93SE's Avatar
STFU n00b!
bosch work in some cars- ones that the engine was designed with those plugs in mind. they are quality in some conditions. many airplanes spec bosch avaition plugs (which are $20-60 EACH), and are not allowed by FAA to use anything but what's on the spec sheet.
but for every Nissan application I've seen, NGK is the stuff to use.
Old Feb 13, 2008 | 06:47 PM
DanNY's Avatar
Ad·min·is·tra·tor
the audi runs on NGK...even on the OEM one you get from the dealer...it's NGK plat
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
