Need to find starter relay.
Old Feb 27, 2008 | 01:42 PM
akurtzer57's Avatar
Turn key on and lights all come on as usual but when turn key to start I can't even hear the relay click. The starter does not engage or spin it is brand new only 2 weeks old. Battery tested at 13.2 volts. New ignition and put test light on wires coming of ignition and there is no kind of short. Also put a jumper wire in the neutral safety switch to test it to. My next step is this relay if I can find which one is which. Read in some old threads it was under the coolant resevoir but didn't see any there just on driverside fender.
Old Feb 27, 2008 | 01:48 PM
internetautomar's Avatar
mod or sell?
it may be the anti-theft system malfunctioning if it is still connected.
Old Feb 27, 2008 | 01:51 PM
nc90gxe's Avatar
http://forums.maxima.org/showthread.php?t=554684
try this too
Old Feb 27, 2008 | 01:55 PM
akurtzer57's Avatar
Originally Posted by nc90gxe
Yes ive read this My car is a manual I put the jumper wire to eliminate that problem if it was it.
Yes the alarm is still connected. Should I unhook it?
Old Feb 27, 2008 | 01:57 PM
BenStoked's Avatar
Jesus was a Zombie.
try unhooking it, just to see if its the problem.
Old Feb 27, 2008 | 08:42 PM
Mike90SE's Avatar
The only way you will have a relay box under your coolant reservoir would be if you had anti-lock brakes. Then your reservoir would be on the driver's side in exactly the same place that non anti-lock equiped cars is.
Old Feb 27, 2008 | 09:17 PM
akurtzer57's Avatar
got it all figured out and it started right up.
Old Feb 27, 2008 | 09:24 PM
Wiking's Avatar
...can't even hear the relay click. ..
Most probably Relay, wire, rotten supply cable under batt tray... sometimes worn ign sw.
Close those possibilities out and test starter relay by giving it direct +12V from battery with a test wire.
http://www.cardomain.com/ride/748507/5
Old Feb 27, 2008 | 09:26 PM
Wiking's Avatar
Cant Figure out what all happened???
Old Feb 28, 2008 | 07:03 AM
mod or sell?
in the US the relay on the starter itself is called a solenoid.
Old Feb 28, 2008 | 07:12 AM
Wiking's Avatar
I definitely wrote solenoid [did I? did] ... E-noids must have re-layed it into atlantic? Next time I'll send over two solenoids.
mikeg75
Nov 30, 2015 05:12 PM
pears
Sep 18, 2015 05:25 AM
rnb754
Sep 14, 2015 11:39 PM
jwright36
Sep 8, 2015 11:45 AM
