Pathfinder Clutch kit/flywheel?
Will a late 80's pathy clutch kit and flywheel fit on a 3rg gen vg? I would assume so because the vg flywheels should be the same, and since the clutch contacts the flywheel... etc. The pathy has a vg too but i tihnk it only made 140 hp, and most likely a different trans, but would the clutch kit and flywheel work? Thanks...
lol, well no, why would it burn up fast? How long is fast? I might be able to get a new clutch kit for a pathy for free, and i wanted to know if it will work, although it now appears i may be able to get the flywheel off a maxima, would the pathys clutch kit work with our flywheel? Thanks.
the only thing in common is the spline count
I pulled the information from the sachs and delco clutch catalogs. the pathfinder is a smidge larger (10mm)
t6378tp
09-29-2018 04:27 PM
spencerwh1
06-30-2016 05:44 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
