Parasitic Draw
Not possible.
The issue was leaking from higher potential to ground. This can happen:
1a. via electronics devices by design
1b. via electronics devices by fault.
2. broken positive wire leaking to ground
3. Oxidized, wet, etc. connector or any positive point leaking to ground
If positive hi potential is missing, leak cant happen. If ground is missing, leak cant happen.
If an xtra route via soot appears from hi potential to gnd, sht may happen.
(Issue not included in this thread: supply resistance in oxidized wirings resulting in no start or whatever electrical malfunction)
it's been a while, but i thought i would update on this situation.
the car still has a parasitic draw which has only been noticeable at temperatures below 30 degrees. I'm thinking that the re-manufactured alternator is to blame. it never did this until i put this alternator on.
The Frye
Sep 2, 2021 11:03 AM
