where is my PVC valve? 92 SE DOHC
Old Mar 27, 2008 | 06:03 PM
MaximaN00b's Avatar
Its behind the intake, rear bank.. down alil bit, 3/4" nut unthreads it? isnt this the pvc valve? see pic
this is what autozone gave me.
Old Mar 27, 2008 | 06:20 PM
Greeny's Avatar
¯\(°_o)/¯
The one they gave you is the correct design, though it looks to be plastic(should be metal.)
The first pic is not a pcv valve for a ve, they do not have a 90* angle on the hose tip.
Old Mar 27, 2008 | 06:40 PM
MaximaN00b's Avatar
yes it is definitely plastic, and when i shake it.. it rattles, i do not like it.. haha
it was cheap, $5.
Ok, so not a 90 angle, that wasnt the pvc valve.
I CANT find it..
where is it??
Old Mar 27, 2008 | 07:01 PM
Greeny's Avatar
¯\(°_o)/¯
it was cheap, $5.
I CANT find it..
where is it??
What the hell is that first pic of then?
Old Mar 27, 2008 | 07:04 PM
92gxe/cg2's Avatar
Well its supposed to rattle, when it doesnt rattle that means the valve doesnt open/close right which is why ud need to replace it, and i got mine from the dealer for like 3 bucks, and it was a nice thick metal pcv valve.
Old Mar 27, 2008 | 07:08 PM
Greeny's Avatar
¯\(°_o)/¯
+1 sometimes the dealership is the best place to buy some parts, the pcv is one of them.
Btw, maximanoob, look in the noobie thread on page 10/post 296 for ve pcv valve info.
Old Mar 27, 2008 | 07:28 PM
mikekantor's Avatar
That 2nd one looks exactly like the brake booster check valve.
Old Mar 27, 2008 | 07:56 PM
Josh's Avatar
Autozone gave me that same PCV when I first tried to change mine and as you know it is the wrong one. That looks like an elbow from the plenum, I think if you follow the hose it was connected to down to the valve cover(lower passenger side) you will find the pcv, its a real PITA to change.
Old Mar 27, 2008 | 08:01 PM
Josh's Avatar
Here is a pick of it that was once posted.
Old Mar 27, 2008 | 08:02 PM
hoyshnin's Avatar
Baby's on the Half Tip!
you can get a good pcv valve at autozone (an all metal one), just ask for the beck-arnley brand (i think that's what it's called).
As for the location, you should just search. This is greeny's pic.
http://forums.maxima.org/showpost.ph...57&postcount=3
(I just saw josh posted a good pic too).
You'll need some pliers to push the clamp ends together to get the hose off and then an extension to get to the pcv valve b/c its wedged in their pretty good, i think you'll need at least an 8" extension.
Old Mar 27, 2008 | 08:04 PM
Josh's Avatar
Too slow
Old Mar 27, 2008 | 08:09 PM
mikekantor's Avatar
I advise removing that hose completely, the corner is prone to developing cracks, and replacing it is expensive compared to normal hoses.
I got rid of that little bracket, and just put in a single hose directly from the PCV to the plenum.
Old Mar 28, 2008 | 05:56 AM
internetautomar's Avatar
mod or sell?
<snip>
that still doesn't means it's good or correct. you are still relying on people who are paid minimum wage to know about a motor that was an option for only 3 years and never offered in any other car/chassis.
do you know how many times I've seen the manufacturers screw up the listings?
Old Mar 28, 2008 | 08:49 AM
hoyshnin's Avatar
Well it is good and correct because I've used two of them and know others that have used them and like them. As long as you tell autozone it is a 93 SE (NOT a 92) then you'll get the correct parts usually. I like to watch the screen as they punch everything in. I agree that a lot of autozone stuff sucks, but this part does work great.
Then again internetautomar probably has pcv valves and he will 100% get you the right one the first time and for a really good price, so you might want to just do that to be sure.
Old Mar 28, 2008 | 09:30 AM
92 Max's Avatar
The PCV valve on this car is on the front of the rear head area. Go to the firewall, in front of the passenger seat, look through the hood bracket on the passenger side, and look all the way down the intake plenum to the valve cover in the rear. Lay your light in between the plenum and the firewall shining down. It sticks out from the head there. It'll have a 90 degree rubber hose with spring clamp on top of it. The only way I got at mine was one of the long (11") needle nosed pliers ( I think the 45 degree bent tip ones). I was just able to grab the spring clamps with these and pull off the clamp and hose. Then a long extension on my ratchet, with a universal joint unscrewed it. The only problem is to not knock all the dirt around it into the hole.
Old Mar 28, 2008 | 09:50 AM
hoyshnin's Avatar
I was able to do it with a normal pair of pliers, but it took a few minutes of getting them in just the right position.
I also used a normal deep socket and extension, i didn't need a universal joint.
Old Mar 28, 2008 | 01:05 PM
92 Max's Avatar
I suppose you could but it's easier with these tools and this is an excuse to buy new tools. Where's the downside?
Old Mar 28, 2008 | 01:32 PM
MaximaN00b's Avatar
thanks everyone, especially greeny, cause hes always answering my questions quickly lol
The reason i wound up pulling the elbow out thinking it was the pvc, was i researched online and it said it was by the rear left firewall, down about 4".. I suppose its partly my fault, for assuming the firewalll STARTS up top by the windshiield blade motor. lol
But i know exactly where it is now, i saw it last night.. Going to order a beck/arnley from the net.. i found the RIGHT one, cause its thread in. I figured they gave me one for a gxe, which probably is located right on top of the valve cover like any other car ive had.
Old Mar 28, 2008 | 01:52 PM
hoyshnin's Avatar
Like I said, you can buy beck/arnley at autozone, save on shipping!
Old Mar 28, 2008 | 01:57 PM
MaximaN00b's Avatar
not in stock, checked.. as i returned that cheap piece of plastic wrong part
check advanced too, no luck. And dealer has none in stock
Already ordered a beck/arnely online.. same price as advanced would have been.. $16
Old Mar 28, 2008 | 01:58 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
idiotzone can have ordered to the store for you and then there would be no shipping costs..
Old Mar 28, 2008 | 03:03 PM
hoyshnin's Avatar
yeah, cancel your online order if you can, $16 is about 4 times too much for a pcv valve.
autozone can have it next day
Old Mar 28, 2008 | 03:17 PM
MaximaN00b's Avatar
Um, go to AZ and check their price for a beck/arnly PVC valve, its as much as i just paid online.. no big deal. And now it gets delivered to my door, UPS groud is usually pretty fast, I should have it by tuesday.
Old Mar 28, 2008 | 04:00 PM
hoyshnin's Avatar
I guess I was thinking checker/shucks/kragen, it's $6 there. I don't know why it's so expensive at autozone, weird. The listing must be screwed up b/c it says it's 3.4 lbs, that's one heavy pcv valve, haha.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
londonflu
40
Sep 25, 2015 09:11 AM
tardrex
Sep 11, 2015 07:35 PM
