strange noise from speakers as I accelerate
Old Mar 29, 2008 | 07:51 AM
Dayle97SE's Avatar
whenever I accelerate, there is a high-pitched whirring noise that comes from all 4 speakers which gets higher in pitch as I accel and lower as I ease off the pedal...I have Bose, all 4 amps were rebuilt within the last couple of years, and my alternator was replaced a year ago...... any other suggestions? anyone else have this?
(please keep comments like "oh man thats messed up" or "bose sucks" to yourself....help and suggestions only are GREATLY welcome and appreciated)
Last edited by Dayle97SE; Mar 29, 2008 at 07:52 AM. Reason: all speakers, not just 1
Old Mar 29, 2008 | 08:51 AM
Wiking's Avatar
Originally Posted by Dayle97SE
... a high-pitched whirring noise ...)
Alt rectifier bad, groundings bad...? Check http://www.cardomain.com/ride/748507/14
http://www.cardomain.com/ride/748507/10
http://www.cardomain.com/ride/748507/23
Old Mar 29, 2008 | 09:04 AM
BenStoked's Avatar
Jesus was a Zombie.
there is a ground loop problem, somewhere, that causes the frequency of the noise to change with the engine rpm.
an example of a "fix" would be something like this....
http://www.radioshack.com/sm-more-pr...i-2062214.html
it'd need to be spliced into the line out wires of the head unit, which will suck.
Old Mar 29, 2008 | 08:42 PM
LvR's Avatar
LvR
+1 on Wiking's suggestion.
Old Mar 30, 2008 | 06:28 AM
maximagician's Avatar
only my rear speakers(which are 6 x 9's and use an old amp)
would do that sometimes so i finally have a different amp
but before changing amps i found out if i hold the r c a input
wires going into the amp tight in place it would go away
and i'd have to re-position my "r c a wire tensioner"
or you can leave it that way and pretend its the turbo whine
Old Mar 30, 2008 | 08:31 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
one time i had an 100W inverter plugged into the cig lighter, under full load, and running on it was a laptop and we had a double-ended headphone cord that you'd use to hook the audio out to the aux in jack on my radio faceplate, and as long as the laptop was plugged into the inverter, it made the same sort of whine through the speakers.
Old Mar 30, 2008 | 07:41 PM
Deridex's Avatar
I get that once in a while. Sounds kinda like an aircraft turbine.
Old Mar 31, 2008 | 11:59 AM
maximaman1313's Avatar
bad grounding is first thing to my head...maybe bad cables, maybe bad amp. wiking seems to have good enough on electrical and good website to look at, go with what he said
Old Mar 31, 2008 | 01:19 PM
Gunther's Avatar
I would bet that's the problem. Happened on the family's conversion van, you could hear when the turn signals were on through the speakers, as well as when putting a window up or down. Ended up just rewiring it.
Old Apr 7, 2008 | 05:16 PM
Dayle97SE's Avatar
Now that i think of it, the turn signals and windows cause the same noise too...what do you mean when you say you "rewired it" ?
Old Apr 16, 2008 | 12:09 PM
projectviper255's Avatar
i have the same problem. but only when i have something plugged into the cigarette lighter.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
