Strut Problem!
Old Apr 24, 2008 | 09:03 AM
str8max's Avatar
Strut Problem!
OK last weekend I tackled the front suspension on my 90 gxe max I did a ton of work on the front.
new control arms
ball joints
inner/outer tie rods
sway bar links
install new cv boot
kyb struts
new boots
eibach springs
ES bushings
i must say that is one nasty a$$ job!
any way last night I began to work on the rear replacing struts and springs (kyb & eibach) and i gotta say what a messed up engineering job when the rear suspension was designed. I got it all replaced in about 5 hours by myself and when I left this morning the rear passenger side is rattling almost every I hit a bump. I haven't had time to check the strut mount but just off the top of your head .org members what sounds like the problem.
I had this same setup on my 5th gen. and the ride was no where near as hard!
oh yeah I have 18's on there as well and so did my 5th gen.
Old Apr 24, 2008 | 09:30 AM
Wiking's Avatar
Originally Posted by str8max
... the rear passenger side is rattling ...
One possibility: For some reason the Gland Packing is not tight enough. If installed w/o loctite, it will even unscrew itself... jack up, wheel off, try tightening ...
Not Grand Placking but The Gland Packing by FSM RA-7
Old Apr 24, 2008 | 10:11 AM
str8max's Avatar
wow never thought about that one!
thanks
i will cranker down!
Old Apr 24, 2008 | 10:47 AM
Wiking's Avatar
On my Nissans this self-unscrew has happened multiple times ... 1-2yrs later (!?), rear and NOT on drivers side. You tell me why. Alcohol cleanup for the threads, add some loctite, problem gone.
I used stanza/bluebird Sachs shocks in rear (here half price). Needs one thick washer on bottom to get it tightened.
matts95max
Apr 23, 2025 10:44 AM
dvcamp
Sep 18, 2015 10:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
Johnny9595
Sep 3, 2015 05:18 AM
