How much to install springs?
Old May 5, 2008 | 06:51 PM
Lumberg™'s Avatar
on this site too damn much
Just springs / axle?
Old May 5, 2008 | 07:02 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
um... u has 3rd gen too?
Old May 5, 2008 | 07:10 PM
Lumberg™'s Avatar
GF's car I bought off another member on here. It's in the shop now for some other work to get it to pass inspection
Shop I have the car at now is trying to charge me $120 an axle and that seems a little high to me. Or maybe not?
Old May 5, 2008 | 07:28 PM
DJ98MAXSE's Avatar
Do it your self. If you have air tools, it only take about 30 mins per corner. Also, most auto parts stores will let you borrorw the spring compression tool for free.
Old May 5, 2008 | 07:37 PM
BenStoked's Avatar
Jesus was a Zombie.
if not for free, for a deposit, get it back upon return(keep reciept!)
and for $120 ea., they better be putting in tok's or gold plated, or something.
Old May 5, 2008 | 07:50 PM
Lumberg™'s Avatar
Come on guys... we're obviously all not mechanically inclined or have the time or space to do it ourselves. If I could do it myself, wouldn't have asked the question.
NEXT
Old May 5, 2008 | 08:16 PM
NEXT
then i'd suggest to get a few quotes from a few different places and see what you can whip up price-wise. You may not trust the other guys, or you might, but you also might be able to leverage your trusted mechanic into doing it for cheaper based on the compeditor's price..
Old May 5, 2008 | 08:38 PM
BenStoked's Avatar
Jesus was a Zombie.
i'm gonna suggest you find out how much cheaper it would be if you supplied the parts. tokico can be had for about $275 anywhere, and like DJ98MAXSE said, for a shop, it shouldn't take 2 hours. figure $100/hr shop rate(guesstimating) and you have about the same price.
Old May 6, 2008 | 06:02 AM
internetautomar's Avatar
mod or sell?
what is the labor rate for your area?
most reputable shops base their quotes on a labor guide which tells them the accepted time it will take for the repair which is then multiplied by the shop's labor rate.
Strut/spring labor:
Code:
Selected Vehicle >>> 	Year:
1992 	Make:
NISSAN-DATSUN 	Model:
810/MAXIMA 	Engine:
V6-2960 3.0LVG30,T,E 	Group:
CHASSIS & STEERING
Back to Part Categories
  Selected Part Group: Shocks & Springs
  	Labor Operation 	Skill 	Est. 	Sell 	Yrs
	  R&I Front Shock &/Or Strut Assembly
1 	    Both 	B 	1.4 	98.00 	92
  	     DOES NOT include disassemble or alignment
2 	    One Side 	B 	0.8 	56.00 	92
	    * R&R Gland Packing &/Or O-Ring
3 	    Each 	B 	0.3 	21.00 	91-92
	    * R&R Spring
4 	    Each 	B 	0.3 	21.00 	91-92
	    * R&R Spring Insulators
5 	    Each 	B 	0.3 	21.00 	91-92
	    * Replace Strut
6 	    Each 	B 	0.3 	21.00 	91-92
  	     Includes: Transfer spring, seat & insulators
	  R&I Rear Shock &/Or Strut Assembly
7 	    Both 	B 	2.6 	182.00 	92
8 	    One Side 	B 	1.4 	98.00 	92
	    * R&R Coil Spring
9 	    Both Sides 	B 	0.5 	35.00 	91-92
	    * R&R Strut Cartridge
10 	    Each 	B 	0.5 	35.00 	89-92
	    * R&R Strut Packing & O-Ring
11 	    Both Sides 	B 	0.6 	42.00 	91-92
	    * Replace Strut Assembly
12 	    Each Side 	B 	0.5 	35.00 	89-92
	  R&R Front Spring
13 	    Both Sides 	B 	2.0 	140.00 	92
	  R&R Rear Spring
14 	    Rear, Both 	B 	3.1 	217.00 	92
  	     DOES NOT include Alignment
	  R&R Rear Strut
15 	    Both 	B 	3.6 	252.00 	92
16 	    One Side 	B 	1.9 	133.00 	92
	  R&R Rear Strut Cartridge
17 	    Both 	B 	3.6 	252.00 	92-94
18 	    One Side 	B 	2.9 	203.00 	92-94
Axle Labor:
Code:
	  R&I F Axle Shaft Assembly
1 	    Both 	B 	1.8 	126.00 	85-94
2 	    One Side 	B 	1.1 	77.00 	91-94
	    * R&R Axle Shaft Boot
3 	    Each Side 	B 	0.7 	49.00 	91-92
	    * R&R Axle Shaft Joint
4 	    Each Side 	B 	0.7 	49.00 	91-92
5 	    * R&R Axle Shft Center Support Bearing 	B 	0.3 	21.00 	91-92
6 	    * R&R Center Bearing Support 	B 	1.0 	70.00 	91-94
	    * R&R Differential Output Seal
7 	    Each 	B 	0.1 	7.00 	91-92
	    * Replace Axle Shaft
8 	    Each 	B 	0.7 	49.00 	91-92
	  R&R F Axle Shaft
9 	    Both 	B 	3.2 	224.00 	85-94
10 	    One Side 	B 	1.8 	126.00 	91-94
	  R&R F Axle Shaft Boot
11 	    Both 	B 	3.2 	224.00 	85-94
12 	    One Side 	B 	1.8 	126.00 	91-94
13 	  R&R Axle Shaft Center Support Brg 	B 	1.4 	98.00 	85-94
	  R&R F Axle Shaft Joint
14 	    Both 	B 	3.2 	224.00 	85-94
15 	    One Side 	B 	1.8 	126.00 	91-94
16 	  R&R F Center Bearing Support 	B 	2.1 	147.00 	85-94
the pricing in those estimates are for a $70 an hour labor rate, which is WAY lower than the prevailing rate around here.
Old May 6, 2008 | 06:51 AM
Lumberg™'s Avatar
Thanks guys... Aprreciate the feedback.
Old May 6, 2008 | 08:46 AM
Matt93SE's Avatar
STFU n00b!
Standard rate is about $120/axle for labor, which is insane since it takes about 15 min to swap an axle.
shocks, pay a local member $150 to do it, or you can pay a shop about $600 labor.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
