When Should The Oil Pump Be Replaced?
Is this one of those parts that isn't necessary to replace until it fails (unlike the timing belt).
If the oil pump dies, does the oil lamp indicator go on immediately? And can I still drive the car for awhile?
U may buy, attach oil pressure gauge and watch how it goes. Healthy pressure is very important, thats why there is a warning light.
If pressure drops out, you have 'five miles to go' - to engine swap. The light may also come/stay on if wire shorts, the pressure switch is blocked or broken, happens sometimes.
Its the 'last' piece to go. I've never replaced in any engine...
Should I just replace it?
By the way, good news I found an invoice from 2 yrs ago - I had the water pump & alternator replaced. Sure I probably got suckered and got refurb...but it's better than nothing right?
I'm doing the radiator and rad hoses this week.
Wiki - do you know where the SWIRL CONTROL VALVE is? Also, what is the hose directly under the CARBON CANISTER?
Be happy. I am just wondering if to replace my pump on next belt swap... I think I'll wait it out...
Generally: Oil light comes on, stop immediately, call tow truck.
For me, its yapping women logic, get dirty time
Canister Hose Pics Pls?
it isn't necessary to replace until it goes, but once it goes you need to realize that your engine has already sustained damage. going 100ft with a bad oil pump (no oil pumping) causes permanent damage immediately.
The oil light itself will typically come one when pressure reaches dangerously low levels. I've seen lights that come on solid at 20 lbs and lights that only start to flicker at 5 lbs. This usually happens when idling, not when driving. If you're oil light is on while driving and the sensor isn't bad then you have more serious problems.
If the oil pump actually dies (as in, stops spinning and pumping ANY oil) you're doing serious damage immediately. This is a rare failure mode for street driven cars though. Usually what happens is the main and rod bearings wear to the point where the pump can't keep the pressure up unless it spinning fast enough. So the light flickers or stays on at idle and goes out while driving. Usually a re-ring & bearing job will get the tolerances back close enough to have good oil pressure even at idle without replacing the pump.
A busy nessman told me: "...yes I saw the red light come on. But as I was busy, I didnt let the pedal. As it happened, five miles later...
If I was doing a complete engine rebuild I'd replace it. If I was doing a re-ring & bearing job I probably wouldn't unless it tested bad or questionable. In general, the oil pump SHOULD last as long as the car so it doesn't normally need replacing.
heh, i've heard some people just call it the "oh shhit light"
The part that hasn't been mentioned yet is that the oil pressure switch could be the problem. If it's clogged with debris or simply failed, the light can/will come on.
remove the oil pressure sending unit and screw a gauge in there. start the car and see what happens. If you have pressure, replace the switch/sending unit. If no, then kiss the engine goodbye.
different thicknesses of bearings are made so that you can machine the wear surfaces on the crank. since the crank is then smaller, you need thicker bearings to take up the space.
It's also done to account for manufacturing tolerances during machining. the crank is just ground round and "close" to the proper dimensions, then the thing is mic'd (measured) and bearings are installed to fill the clearance.
Thanks everyone. No - the oil light never came on, in fact I've never seen it come on ever. The reason I was asking, is that I have stuff open right now, so I thought for not that much more labor, I could just do the pump...even though 'could just do' may be an understatement.....I'm not sure how accessible it is, have to check the manual.
Then there somewhere is a problem: it should be on always w/o pressure. Like ign ON, engine off... Switch broken, connector out, wire cut, bulb burned, sight impaired or statement off?
he asked if the light comes on when you turn the key on but don't crank, it. if the bulb is burned out, or the light does not come on under that condition then you have problems too. meaning that if the oil light DOES come on you'd never know. because it's burned out or has a broken wire or w/e.
Good u patched up my gibberish... thks.
--> When engine is OFF.
----> Ignition key turned to ACC.
= ALL warning lights must come ON. Every time. This is the time when driver responsibility sets in: You have to check that all lights work. If not checked, keep at least cell phone loaded and tow truck number at hand...
They gauges used to be the capillary pipe, gas filled type, 'pressure gauge' [eh, here we are again in the LOAD signal sector...]
These were always lea king = a king u dont want to meet
, no peace but s itting on butterflies.
So had to learn to get by w/o gauge: as long as cabin heater blows hot, u can drive. When it stops, you'll stop after one minute - or immediately. Cabin heater also work as extra cooler [like: when Morris Mini own mini rad overflows...]
, no peace but s itting on butterflies.So had to learn to get by w/o gauge: as long as cabin heater blows hot, u can drive. When it stops, you'll stop after one minute - or immediately. Cabin heater also work as extra cooler [like: when Morris Mini own mini rad overflows...]
I am King's son, brains in bits an pieces. Tech no bits wont give peace but The King will
I was hiding in the woods when ey came an captured me: sailing aimlessly since then as a captive.
But yes, been filling capillary temp gauges with vacuum/gas as young lad in the steelworks. Gettin trains tecno brains rollin... Tech No Silence is My Music: http://www.cardomain.com/ride/748507/17
