Need to Unhook AT Oil Cooler Lines (2) - Will it drain and how long can it sit empty?
Old May 22, 2008 | 02:53 PM
1993-VG30E-GXE's Avatar
I need to replace the rad this week...so 2 questions:
a) When I unhook the AT Oil Cooler lines will fluid drain (I want to replace the hoses & rad), and if it does, can I leave the car empty (sitting) for a week or two without tranny oil?
c) If I drain the coolant from the car, can I leave the car empty (sitting) for a week or two without coolant in it until I get into putting the new Rad in?
Old May 22, 2008 | 03:30 PM
BenStoked's Avatar
Jesus was a Zombie.
neither should be a problem as long as the car is not started or moved. think about this: when you pull an engine or tranny from a junk yard car (or more specifically, a yard does it, and it sits on a shelf before its bought), no special work is really done. its just yanked out, and set somewhere to await its next use.
Old May 22, 2008 | 03:43 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yeah it's no worse than having a VE and getting new axles, only to find out they gave you the wrong ones and your car had to sit w/o axles for a few days while they got the right ones shipped in. trans is "open" sort of b/c there's no axles in it.. doesn't hurt anything
Old May 22, 2008 | 04:20 PM
internetautomar's Avatar
mod or sell?
order the axles from the professionals next time
to the OP:
enough fluid is left in the system at different points that it will be fine to sit for the short period without issue.
Personally I wouldn't take anything apart until the new parts are in.
Old May 22, 2008 | 04:27 PM
to the OP:
not a problem for me haha.. i has a VG. but yea if i ever need any i'll get them from that guy up in chicago with the site full of maxima parts
Old May 22, 2008 | 05:49 PM
Thanks dudes - and what about the AT Oil Cooler Hoses. When I remove those to measure them for the new replacements...or to put the new replacements in, will all or half of my tranny fluid start draining out?
Old May 22, 2008 | 07:19 PM
mod or sell?
some fluid will come out, just make sure to refill before you go for a drive
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
kjlouis
Oct 3, 2015 05:29 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
