Dyno results inside>>>>
Old Nov 3, 2000 | 07:51 PM
CandiMan's Avatar
Say Candyman 5 times
The last time I dynoed my ride I got 168.6hp and 173.3ft-lbs. The mods I had at the time was CAI, custom y-pipe, 2.5" exhaust piping, and larger cat, but I was using the OEM muffler. Since then I have installed a UDP and advance the timing 5* Have not had a chance to dyno these two mods, kinda waiting until the custom headers are done then I get a baseline before and after the headers. Keep in mind I have a auto tranny. Once I get to the in-laws I'll scan the dyno graph and post at a later date.
Old Nov 3, 2000 | 08:03 PM
FAST4EN's Avatar
Hey where did (are) you getting your "customizations" done at? If it's a local place, give me some examples of national places that would do it please. Thanks
Old Nov 3, 2000 | 09:07 PM
Nismo87SE's Avatar
Man those are very good numbers for an auto. I could realistcly belive you can get around 175-180hp with bolt ons if your auto is this strong. BTW you should get a Protorque torque convertor. Its the perfect complement for those mods. I would like to see the torque curve so I can compare it to a VQ. You might want to try boring out the TB to 70mm too. The TC will make a nice difference to believe me, if you wanted 3000rpm launches with WOT with little wheelspin. This is the mod to do. Also when you install it replace the rear engine seal adn both drive axle seals.
Old Nov 4, 2000 | 02:24 AM
CandiMan's Avatar
Attn FAST4EN>>>>>
Not too sure if you ever to go the 3rd gen BBS, but if you do I just posted the info you're looking for in the discussion section. It's under "Nismo87SE here's a few pics including dyno graph"
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
