gas needle jumping
gas needle jumping
I was driving my car yesterday, and i had just a little over 1/2 a tank. i get on the freeway, and notice my gas gauge has dipped to almost 1/4. I almost freaked! anyway, I try to pay attention to it the best i can(rush hour is not the time to be monitoring gauges), and I notice it's fluctuating between just under 1/2 and just under 1/4. finally I get to where im going, and watch the gauge with the engine running. sure enough, its still moving, altho not as much, just twitching, up and down, just below 1/2 tank(where it should be after the drive).
this has me slightly worried, and was wondering if anyone knew the cause.
is my sending unit dying? is my gauge? is there a semi-common problem that needs to be checked?
mine has been like that for 2 years. i figure it was the sending unit or the floater in the tank. and i say this because it seems to work perfectly until after below 1/2 tank. nissan dealer in st charles, mo qouted me sending unit and fuel pump(one peice) for over $400. i personally watch my trip. i get 410 miles till gas light comes on, which i assume it works fine.
Was it fluctuating gradually or rapidly? I would think that if it were the latter, it might be that the sensor was getting a mixed reading. Another thing is how often does this happen? Was this the first time or has it been consistent (like when you are driving on a flat stretch of road or going up and down)? Just a few thoughts so that you might not have to hunt for a new instrument cluster.
meh, I dont need to get another gauge set. somewhere, around my mess of a computer, is my original gauge cluster... it should be okay, still.
obsession: the meter only does it under 1/2 tank, and it bounces pretty quickly. it isnt like dropping a ball bearing on concrete quick, but it will go from 1/2 to e in about the same speed that it would when you fill your tank up from half, and turn the key.
any fluctuation moves with the same speed, and varies depending on its... mood?
as for hills or flat roads, I live in oklahoma. there are no hills here, only rolling planes. sure it goes up-and-down, and I havent proven these movements to coincide with those rolls. (if you have ever lived in okla., you'd understand for sure.)
My fuel hand stays on E it doesnt move at all. I never noticed my gas hand jumping or anything. I started my car up one morning and noticed my gas hand was on E with a full tank of gas. I have a '07 Max any suggestions?
*Don't bump a thread that not only is 4 years old, but a thread that is 4 years old, in a section of the forums that doesn't even pertain to you!
*Go up to the top, where it says "Maxima Forums>Maxima Discussions>...click that, then find where it says "6th generation maxima". Click that. Then read for other problems like yours.
*post thread if after reading and searching you don't find anything.
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
