Exhaust Manifold (Rear)
How much harder could it be to get off??? i got the 3 top bolts off, and the bottom 3 are nearly impossible.
Yes, this is off the parts car. and yes, i ripped all the hoses that were in my way outta my way.
you should just be able to snap the bolts off, if not, try spraying it with liquid wrench or pblaster, then heat the nuts cherry red with a propane torch and have it. If the nuts had stripped, then perhaps one of those sockets that grabs on to stripped nuts can be used as well. If you really don't care, air hammer and chisel point will get the job done, or just hammer and a chisel.
i recommend, if using the pb blaster, etc. method, give it time to soak in, then wipe away any excess before using the torch.dont need a fireball under the hood(even if its a parts car.)
I'm confused. I believe myself to be a large man, being of 330 pounds (Yeah, I know it hurts my 1/4 mile time). But even I can get to all 6 bolts from the top, especially if all the vacuum lines and stuff are pretty much out of the way. So, I second the comment of either get better tools or pull the engine. The only other option I can offer, is to pull the right side valve cover. If you can't get to the bolts at that point, then you're doing something really wrong. That cover comes off with a big head phillips screwdriver in about 3 minutes if indeed your lines are out of the way.
Remove the Xmember and you'll have plenty of room from the bottom, or a small stubby rhachet with a deep 6 point socket should work from the top. Relax you don't need to see it to remove it, use a mirror and flashlight! May the force be with you! Close your eyes and feel the force!!!
vingodine
45
05-21-2016 12:46 PM
Huttig2009
09-25-2015 03:31 PM
MAXSE5SPD
08-23-2015 12:06 PM
CAN-Other LF: Worn / Broken Parts
george__
08-18-2015 07:06 PM
