Help! Fuel filter!
Old Nov 5, 2001 | 03:14 PM
CoolMax's Avatar
is invisible
Help! Fuel filter!
http://forums.maxima.org/showthread....threadid=73503
I can't get the freaking hoses of the filter! It's as if this is the first time in 10 years it's been touched (it probably is)!
What do i do?
Chris? Dan?
Help!
Old Nov 5, 2001 | 03:47 PM
Brian_TII's Avatar
PULL!!! If that doesn't work you probably have enough slack to simply cut it... Or you can take this time to replace those fuel lines....
Good luck,
Old Nov 5, 2001 | 03:58 PM
adamlacey's Avatar
mine was a ***** to pull apart.. u just gotta use some elbow grease.
Old Nov 5, 2001 | 05:00 PM
rambo91145's Avatar
i had to cut mine, and there was plenty of slack, but then i decided to just replace it. i replaced it with a blue hose, but i ve seen clear and it was cool too. i also replaced the other rubber tubing in the engine with blue. its not too expensive and makes it look nice IMO
Old Nov 5, 2001 | 07:08 PM
CoolMax's Avatar
is invisible
Thanks guys!
I ended up getting the damn things off by heating up some pliers with boiling water and pouring the water on the hoses...after much vigorous twisting, phew!
Old Nov 5, 2001 | 11:08 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
well at least no one suggested using a flame to heat the lines
Old Nov 6, 2001 | 06:56 AM
HoJo's Avatar
I hope you used hose that was rated as high pressure fuel hose, if so cool, if not I'd change it. Regular hose can't withstand the high psi that the fuel pump delivers on a fuel injected engine.
Old Nov 6, 2001 | 06:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
#1 reason why certain people should not work on their cars. i'll have the marshmellows rdy when it goes on fire.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
