TRACTION CONTROL?
Old Jul 16, 2008 | 11:39 PM
burhan92SE's Avatar
TRACTION CONTROL?
is dere any traction control in 3rd gens? i went to local auto shop today and they were asking if i have maxima with ABS+TRACTION CONTROL OR ONLY ABS...i was like wat? i got ABS but no traction control niether i have ever seen one in 1989-1994 maxima's....hes like ya there is well i said no to him and bought my axel with ABS only.....is there any traction control?
Old Jul 17, 2008 | 12:21 AM
NismoChi's Avatar
No, 3 gen never come with traction control. Air bag and ABS were options.
Old Jul 17, 2008 | 07:07 AM
mikekantor's Avatar
My tires control traction
Old Jul 17, 2008 | 07:13 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
that and my right foot and my left one...
Old Jul 17, 2008 | 08:40 AM
3g94MaxGXE's Avatar
My Maxima doesn't have ABS but it has traction control....thanks to me having a brain and that little switch that says A/T.
I'm kinda glad I don't have ABS from what I've heard its just idiotproofing the brakes which may slow down your braking. I for one know the limits of my brakes.
Old Jul 17, 2008 | 08:56 AM
i wouldn't rly call that power/comfort switch traction control... it won't stop you from spinning tires at takeoff. the setting you are in could conceivably help reduce tirespin once you are moving, by being in a gear less prone to spin the tires (i guess this would be comfort mode which would do that for having less mechanical advantage). but the threshold at which the power/comfort actually comes into play is at lower throttle positions than would REALLY make a difference in terms of having traction or not having traction. if it affected shift points even at WOT, then maybe. But past 3/4 throttle or 7/8 or something, power/comfort shift at the same speeds.
Old Jul 17, 2008 | 09:25 AM
hoyshnin's Avatar
Baby's on the Half Tip!
He was probably talking about a limited slip differential (lsd), right? Most(?) VE5s have them, mine does.
Old Jul 17, 2008 | 09:35 AM
oh..... duh. good point. all VEs a/t or m/t have the VLSD.
Old Jul 17, 2008 | 10:55 AM
nismax1994's Avatar
well if you are having too much fun in the snow it might go in to fail-safe mode which cuts down on the spinning
Old Jul 17, 2008 | 02:06 PM
internetautomar's Avatar
mod or sell?
BINGO!!!
All USDM VEs were originally equipped with a VLSD.
Old Jul 17, 2008 | 04:12 PM
gapboi210's Avatar
Some systems are just setup to look up parts and some criteria applies where other times it doesn't. Cases like this. I think in the Autozone system if you key in a 3rd gen Max it asks if it is a coupe or sedan.
Old Jul 17, 2008 | 06:09 PM
GRNMAXDMON's Avatar
or maybe it might be asking to see if the car came equipped with the sonar suspension
Old Jul 19, 2008 | 01:52 PM
burhan92SE's Avatar
so every single VE comes with VLSD?
Old Jul 19, 2008 | 01:58 PM
1992maximase30's Avatar
think it was standard on a ve-5 but optional on the ve-a.
as for traction control i guess you can say:
you take off in the rain. the wheel spins. speedo reaches 35mph.tcu shifts to 4th gear.
Old Jul 19, 2008 | 06:13 PM
burhan92SE's Avatar
i just read in FSM of 3rd gen maxima they says that...transmission code which ends with letter V is equipped with VLSD.....so mine ends with V but is automatic so i have it for sure...
Old Jul 19, 2008 | 07:56 PM
mod or sell?
every USDM VE came standard from the factory with VLSD.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
